Go to Post It is hard to write code that conforms to a standard that isn't published... - AustinSchuh [more]
Unread 08-01-2016, 14:38
riftware riftware is offline
Parent Mentor
AKA: Andrew Chandler
FRC #0031
riftware is an unknown quantity at this point
Re: 12V power supply for roborio
I'm thinking about getting one of these for our benchbot
http://www.ebay.com/itm/100-AMP-CONT...EAAOSwBahVA8Ar
Supposedly 12 100 AMP - Put the normal connector on it (Anderson? ) and use it through the pdp just like it was a battery. I'm thking 100 AMP would be enough even to power 2 CIM's if they have no load on them right?
Unread 08-01-2016, 17:29
Ari423's Avatar
Ari423 Ari423 is offline
LabVIEW aficionado and robot addict
AKA: The guy with the yellow hat
FRC #5987 (Galaxia)
Ari423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant futureAri423 has a brilliant future
According to Andymark, a CIM motor's free current is 2.7 amps. That is if it has absolutely no load on it. 100 amps will be more than enough to power 2 CIM motors at free speed. The problem comes when you attach them to gearboxes and wheels. I'd still say with a properly geared gearbox that you're pretty safe doing a 2 CIM drive off a 100 amp power source.
2017-present: Mentor FRC 5987
2017-present: CSA for FIRST in Israel
2012-2016: Member FRC 423
2013: Programmer
2014: Head Programmer, Wiring
2015: Head Programmer, Wiring
2016: Captain, Head Programmer, Wiring, Manipulator, Chassis, CAD, Business, Outreach (basically everything)
