Go to Post And if you are unhappy about me using "robot", let me break your heart over what we've done to the word "cheesecake". - Foster [more]
Unread 08-01-2016, 22:16
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Again not knowing the rules at all, but the way I see it the caster ball only has one moving part
Unread 09-01-2016, 08:33
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: [FTC]: Caster?
Originally Posted by dradel View Post
Not familiar with ftc rules, but would this work?
http://www.mcmaster.com/#ball-casters/=10ll5k3
A ball and socket joint, while only having one moving part, has two degrees of freedom: altitude and azimuth, or latitude and longitude.
Unread 09-01-2016, 09:01
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Re: [FTC]: Caster?
For competition robotics purposes, casters are evil and should be avoided.
Unread 09-01-2016, 10:00
pilum40 pilum40 is offline
Steve Miller-Coach-Team 3355
AKA: Steve Miller
FRC #3355 (Bigg Redd)
pilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud ofpilum40 has much to be proud of
Re: [FTC]: Caster?
Indy:
sorry to be obtuse. My team is asking me why casters are evil? Again, I'm just a teacher, not an engineer. Not trying to be funny but legitimately would like to give them a reason why. It's a teachable moment for all. thanks for your patience.
Unread 09-01-2016, 10:48
IndySam's Avatar
Re: [FTC]: Caster?
They are never in the position you want them to be in and can cause irregular movement.
They also violate one of the rules of competition robotics: If it touches the floor it must be powered.
Unread 13-01-2016, 13:46
RRLedford RRLedford is offline
FTC 3507 Robo Theosis -- FRC 3135
AKA: Dick Ledford
FRC #3135 (Robotic Colonels)
RRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond reputeRRLedford has a reputation beyond repute
Re: [FTC]: Caster?
You are conflating the term "rules" With "rules of thumb" that good designers follow.
The official game rules of the Res-Q competition do not exclude the use of casters, unless perhaps they have both a swivel and a shock absorber too (2 degrees of movement freedom → rotation & elevation).
Three wheeled drives are rather tippy and unstable. Casters can typically get turned away from desired direction too often and too easily, especially if you will ever be trying to back down the mountain.
If your star wheels work well, I assume that going for the 40 points that reaching the high mountain zone would give you in autonomous would be possible, but getting back down without a rear caster becoming stuck on churros would be near impossible and risk a rollover backwards.
I am glad to hear someone has done a pair of front "star wheels" that successfully navigate the mountain & churros.
Mecanum wheels will not work very well as only a pair at rear, since they are meant to be used as a set of four located at the corners of a square.
A driven pair of of at least 4" diameter omni wheels at rear would likely work best, and give good results both on the mountain and in the floor.
-Dick Ledford
FTC 3507 RoboTheosis
FRC 3135 Robotic Colonels
