Go to Post IMHO, [the driver's] job is to drive the robot. The coaches job is to monitor everything in a match that isn't your robot. - CalTran [more]
Unread 08-01-2016, 20:15
False1710's Avatar
False1710 False1710 is offline
2015 Team 1710 Chief Design Officer
FRC #1710 (Ravonics Revolution)
False1710 is on a distinguished road
Team 1710 WCD Progress
Here's some of team 1710's progress on West Coast Drive this year.
https://drive.google.com/file/d/0B9Y...p=docslist_api
Unread 08-01-2016, 20:23
Cash4587's Avatar
Cash4587 Cash4587 is offline
AKA: Cooper Cash
FRC #4587 (Jersey Voltage)
Cash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud ofCash4587 has much to be proud of
Re: Team 1710 WCD Progress
If you ever have to replace the belts, That is going to be one hard job..
Unread 08-01-2016, 20:24
Jay Burnett Jay Burnett is online now
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
Are those side rails (the ones that have the wheels) curved?
Unread 08-01-2016, 20:27
Cash4587's Avatar
AKA: Cooper Cash
Also, how do you plan to attach your electronics to the belly pan? Do you plan to use nuts and bolts?
Unread 08-01-2016, 20:44
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Think there was a bit of heat deformation there
Unread 08-01-2016, 21:31
samfruth's Avatar
samfruth samfruth is offline
Team Role: Driver
samfruth will become famous soon enough
We brazed the chassis ourselves and ended up deforming it slightly. This was the first time we'd tried that.
I kind of know programming
Unread 09-01-2016, 00:07
False1710's Avatar
We are going to fix this by using smaller pulleys that leave the belts entirely above the bellypan.
Yes.
Unread 09-01-2016, 00:09
False1710's Avatar
Spot on! We couldn't use a TIG welder so brazing is the best we could do. Unfortunately, this caused a few unforeseen problems, so we will not be using this method again.
Unread 09-01-2016, 08:10
philso philso is offline
FRC #2587
What sort of equipment were you using? What sort of problems were you having?
Unread 10-01-2016, 14:42
False1710's Avatar
We used brazing rods and an oxyacetylene torch as well as a wooden jig we made and some clamps. This caused serious warping of the aluminum and the expansion of the aluminum made it pop out of place even while clamped. Also, we accidentally heated one spot too much and one of the bumper supports fell off!
