Go to Post Though, of course, if the old one you like is shot, then you can just beat your new one with a hammer until it works the way you want. - Kevin Sevcik [more]
Unread 09-01-2016, 12:44
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
FRC Field 2016 Download
Here are the links to A360 for the Autodesk Inventor and STEP format files for the FRC field 2016.
FRC Field 2016
http://a360.co/1Rs6VPs
FRC Field STEP 2016
http://a360.co/1UF7R0t
Autodesk Inventor
1. All the parts are grounded in the main assembly. The game allows for the field to be changed, so remove the grounded status from any structures and then move to a new location adding constraints or grounding as required.
STEP
1. The parts will not be grounded when you open the file. When I open a STEP file I ground the parts to get started.
Please let me know if the download works OK. I have tested it and worked for me.
All the best for 2016.
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 09-01-2016, 12:58
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: FRC Field 2016 Download
Download works fine for me. Thank you for doing this Phil. Much appreciated!
Unread 09-01-2016, 13:25
Can you email me at phil.dollan@autodesk.com to follow up on the R3 update question.
Thanks
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 14:49
Chris Endres Chris Endres is offline
Play hard, Work harder
AKA: Topher
no team (WildStang)
Team Role: CAD
Chris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really niceChris Endres is just really nice
When converting either file to solidworks, it either completely breaks or creates spheres where objects are supposed to be. Can someone convert to solidworks and post a download?
2009 FLL Illinois State Champions - iLEGO
2010 FLL Illinois State Champions - iLEGO
2011 FLL Illinois State 3rd Place - iLEGO
2011 FLL Illinois State 1st Ambassador - iLEGO
2013 FRC Milwaukee Regional Champions - WildStang
2016 FRC Midwest Regional Finalists - WildStang
Unread 09-01-2016, 15:22
Are you opening the STEP file in SW?
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 16:02
AKA: Topher
no team (WildStang)
Team Role: CAD
I am opening the step file in SolidWorks, as well as trying to open the Autodesk file and converting it, no luck either way.
Unread 09-01-2016, 16:10
OK. Let me try a couple of different work flows and I will get back to you.
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 16:14
AKA: Topher
no team (WildStang)
Team Role: CAD
Ok, thanks!
For reference, this is what opens when I open the STEP file.
Unread 09-01-2016, 16:17
Not even close!
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 17:12
ntrishul24 ntrishul24 is offline
FRC #4099
ntrishul24 is an unknown quantity at this point
Hello Phil,
Is there any word about when the 2016 KOP CAD will be out? We specifically need am14U3 so we can start to play with it.
Thanks!
Unread 09-01-2016, 17:14
Glad you asked. Currently uploading!! Check within an hour or 2 for the download link. I will probably start a new thread.
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 17:19
AKA: Topher
no team (WildStang)
Team Role: CAD
Not sure what CAD program you are using, but here is the link to SolidWorks KOP files.
https://www.solidworks.com/sw/educat...gn-contest.htm
Unread 09-01-2016, 17:44
Chris,
If you still need the field model try these formats. One is IGES and the other is STL
http://a360.co/22SQS0G
http://a360.co/1mNAsWl
Phil Dollan
Autodesk Inc.
Unread 09-01-2016, 20:31
alecmuller's Avatar
alecmuller alecmuller is offline
FRC #2342 (Phoenix Robotics)
alecmuller will become famous soon enoughalecmuller will become famous soon enough
Thanks for doing this!
For what it's worth, the STEP file imported fine for me in SolidWorks 2015 (which I think is analogous to the student version for 2015/16).
Here's a view from the middle driver's station (using the camera and perspective):
Unread 09-01-2016, 21:16
808brick 808brick is offline
FRC #2439
808brick is an unknown quantity at this point
Smile Re: FRC Field 2016 Download
Thank You, Greatly appreciated!
