Go to Post Unfortunately, not everyone is Andy Baker. If everyone had this mindset, there would be far fewer problems. - Kevin Kolodziej [more]
Unread 09-01-2016, 13:48
Nathan Powell's Avatar
Nathan Powell Nathan Powell is offline
The Prime Function
FRC #2582 (PantherBots)
Nathan Powell is an unknown quantity at this point
Error Installing WPI Library for C++
Greetings, all.
I am trying to install the WPI C++ library on a couple of offline computers for my team to use. I successfully installed Eclipse and tested it using the standard libraries and Cygwin. However, when I try to install the WPI C++ development tools using the offline method described on Screensteps, it gives me this error:
Cannot complete the install because one or more required items could not be found.
Software being installed: Robot C++ Development 0.1.0.201601072029 (edu.wpi.first.wpilib.plugins.cpp.feature.feature. group 0.1.0.201601072029)
Missing requirement: edu.wpi.first.wpilib.plugins.core 0.1.0.201601072029 (edu.wpi.first.wpilib.plugins.core 0.1.0.201601072029) requires 'bundle org.eclipse.ant.launching 1.0.200' but it could not be found
Cannot satisfy dependency:
From: WPILib Robot Development Core 0.1.0.201601072029 (edu.wpi.first.wpilib.plugins.core.feature.feature .group 0.1.0.201601072029)
To: edu.wpi.first.wpilib.plugins.core [0.1.0.201601072029]
From: Robot C++ Development 0.1.0.201601072029 (edu.wpi.first.wpilib.plugins.cpp.feature.feature. group 0.1.0.201601072029)
To: edu.wpi.first.wpilib.plugins.core.feature.feature. group [0.1.0.201601072029]
Would it be a problem with the way I installed Eclipse, perhaps? Or the offline package I am using?
Thank you in advance for any assistance provided.
"What's this I keep hearing about always blame programming?"
Unread 09-01-2016, 23:01
sparkydp sparkydp is offline
AKA: David Page
FRC #0435 (Robodogs)
sparkydp is on a distinguished road
Re: Error Installing WPI Library for C++
We had the same problem with the offline package, using the online install worked though.
Unread 10-01-2016, 01:35
Cel Skeggs Cel Skeggs is offline
Robot Software Manager Alumnus
AKA: Previously known as Colby
FRC #1540 (The Flaming Chickens)
Cel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of lightCel Skeggs is a glorious beacon of light
Perhaps you should try also manually installing this plugin on the target machine?
Software manager alumnus. Developer of the CCRE, a powerful robot code framework based on dataflow and composibility.
Refer to as she/her/hers. Years of FRC: 2012, 2013, 2014, 2015, 2016. FLL for a few years beforehand.
Team 1540: The Flaming Chickens | Portland, Oregon | Twitter | Facebook
