Go to Post Why assume a full trophy case and spreading the message of FIRST (mentoring rookies) are mutually exclusive? Team 16 supported 6 rookies this season and earned 5 banners - I am equally proud of both. - Meredith Novak [more]
Unread 09-01-2016, 13:43
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: The Audience Agreement
I encourage you to think further about the drawbridge. Maybe consider the definition of crossing. Remember that each alliance has three robots.
Anteprefix's Avatar
Anteprefix Anteprefix is online now
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
Originally Posted by Tanis View Post
My interpretation is the other way around.
Based on the definition of each alliance's CASTLE and SECRET PASSAGE (which are both on the same side of the field), I am assuming that the blue alliance's OUTER WORKS is on the same side of the field as the blue alliance's CASTLE and SECRET PASSAGE.
This means the rule 5.5.10:
Would indicate that the red alliance picks the defenses that are placed leading into the blue alliance's COURTYARD, and thus the defenses that they are going to traverse.
If it were the other way around (you pick the defenses your opponents need to traverse), the last sentence in the quoted piece of 5.5.10 wouldn't make sense- you wouldn't necessarily get the same defenses that you practiced with.
Isn't the section you quoted from the rules only for practice matches?
The scouting! It never ends!
5.5.10 specifically calls out that it's PRACTICE matches.
Think about this: If you are picking your own crossings, why does the DC give you your opponents' selections? (5.5.10.2)
From the rest of the Manual, it is pretty clear to me that you pick your own Defenses.
Unread 09-01-2016, 13:57
Spiffizzle's Avatar
Spiffizzle Spiffizzle is offline
Makes up for height in personality!
AKA: Zara Simpson
FRC #1111 (Power Hawks Robotics Team)
Spiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud ofSpiffizzle has much to be proud of
Send a message via AIM to Spiffizzle Send a message via Yahoo to Spiffizzle
As far as I can tell, in PRACTICE MATCHES you choose for the opponent for the sake of practicing crossing them.
In QUALIFICATION MATCHES, Alliances pick their OWN defenses and then the DC exchanges the plans (with the audience selected section still unknown) so that you know what to expect and have one match's time to strategize how to capture your Castle in queuing!
Interestingly, teams should pay attention to Practice Matches to track what defenses teams prefer to cross... That will be a big scouting question that will later mess teams up because you've probably told the opponent which defenses you can't cross.
Zara Simpson
Team 1676 - The Pascack Pi-oneers - 2008
University of Maryland
- BS Materials Science & Engineering 2013
- MEd Middle School Mathematics and Science 2016
Unread 09-01-2016, 13:59
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
Looking back at the start of section 3 of the manual, I agree.
FIRST STRONGHOLDSM is a medieval tower defender game in which two (2) ALLIANCES of three (3) Teams each select DEFENSES to fortify their OUTER WORKS
I think you are correct that my original interpretation is only true of practice matches.
Team 2052- Knightkrawler
Mentor and volunteer
Unread 09-01-2016, 19:18
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
So true (a little reverse help with either Sally Port or Drawbridge for many, may be fully appreciated on many alliances in StrongHold). But, I was attempting to point out that both defenses actually open toward the midline directions and not toward the Tower directions on each side of the field. Headache.
Unread 09-01-2016, 19:21
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Originally Posted by jeremiahL View Post
I think that a relative easiest barrier would be debatable based on the area you're in and the designing process taken on by most teams, drawbridges would of course be easiest more than likely. seeing as it solely requires one to push on the obstacle.
This is an incorrect understanding. The drawbridge is facing towards the neutral zone, meaning that it is easy to return from the courtyard to the neutral zone, but in order to damage it, you must pull the drawbridge down with some apparatus and cross it.
EDIT: The relevant line from the Game Manual, paragraph 1 of section 5.5.10.1 AUDIENCE SELECTION OF DEFENSES, page 100:
Prior to each round of Qualification and Playoff MATCHES, the audience selects one of the DEFENSES used by both ALLIANCES on the FIELD. The Audience selected DEFENSE is located in the OUTER WORKS position 3 for both ALLIANCES. The selection process is managed by the Herald (MC) and overseen by the Head REFEREE. The DEFENSE which receives the loudest response, as judged by the Head REFEREE, will be the chosen DEFENSE for the upcoming round of MATCHES.
Unread 11-01-2016, 21:56
jeremiahL jeremiahL is offline
Mechanical captain
FRC #3875 (Red Storm Robotics)
jeremiahL is an unknown quantity at this point
every team can start with a spy bot inside of the enemy defenses. push and let the other through man. just cycle all the defenses
Unread 11-01-2016, 21:57
Mechanical captain
i am referring to using the spy bot as a means of opening the gate for another team member to enter the courtyard.
