| Thread Tools |
Rating:
Display Modes |
#61
Re: FIRST STRONGHOLD Discussion
Andymark
#62
You can have a human player direct you, since it's hard to see what your doing on the opponents side from your driver station
#63
This question is interesting.. I think you can weaken/damage your own defenses. Correct me if I am wrong, but that's my interpretation of the rules so far
#64
Btw, doesn anyone know if flying is illegal?
#65
Can you go from the courtyard to the defense? Or do you have to use the secret passage?
#66
#67
From YOUR side, you can use the secret passage. If you're on THEIR side (where you're trying to score), you can't.
#68
Ok... how do you get back from their side you're scoring on to the neutral zone?
#69
Personally, I'd take a Sally Port or a Drawbridge.
#70
ok thanks... the sally port would be a win win because you can get another robot over there and break their defenses.
#71
so is there anything stopping us from going back and forth on an defense to get points? and would our defenses be weakened if we pass through it? and does it count as weakening defense if we cross one from the enemy side to the neutral zone?
#72
Is there a maximum height from the ground to the bottom of the chassis?
#73
You only get points for crossing a particular defense once, after that no points are awarded. Also it seems as if passing through your own defense does weaken it, so take the secret passage. And a crossing is defined as going from neutral over the defense and onto the enemy courtyard.
#74
Some people on my team think you can do it twice before no points will be awarded (logic is its undamaged, then weakened, then damaged, and since it is not damaged till crossed twice you would get points) do you have a rule to back up what you have said? Last edited by MikLast : 09-01-2016 at 14:17. |
#75
