Go to Post CD is a forum provided by a group of people. You use it with their permission. Don't like it? Don't use it. - Andrew Schreiber [more]
Unread 09-01-2016, 14:28
2791GreenFlare 2791GreenFlare is offline
FRC #2791
2791GreenFlare is an unknown quantity at this point
Exclamation Re: FIRST 2016 Game Manual Mistakes
One error in the obstacle of the moat was that the depth of the moat is 2 inches not 2 feet. 2 feet is statistically impossible so it only makes sense to be 2 inches.
Unread 09-01-2016, 14:30
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
I already answered this at your other thread, but this is NOT an error because the "depth" in the manual is referring to the distance across the moat.
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 09-01-2016, 14:40
Anteprefix's Avatar
Anteprefix Anteprefix is online now
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
Section 5.3.3 Ranking Score says
Ranking Points are units credited to a Team based on their ALLIANCES’ performance in Qualification
MATCHES. Ranking Points are awarded to each eligible Team at the completion of each Qualification
MATCH:
A. Each Team on the winning ALLIANCE receives two (2) Ranking Points.
B. Each Team on the losing ALLIANCE receives zero (0) Ranking Points.
C. In the event of a tied score, all Teams receive one (1) Ranking Point.
D. Each Team on an ALLIANCE that CAPTURES a TOWER receives one (1) Ranking Point.
E. Each Team on an ALLIANCE that BREACHES the OUTER WORKS receives one (1) Ranking
Point.
Exceptions to A-D are as follows:
F. A SURROGATE receives zero (0) Ranking Points.
G. A DISQUALIFIED Team, as determined by the Head REFEREE, receives zero (0) Ranking
Points in a Qualification MATCH or causes their ALLIANCE to receive zero (0) MATCH points
in a Playoff MATCH.
H. A “no-show” Team is DISQUALIFIED from that MATCH. A Team is declared a no-show if no
member of the DRIVE TEAM is in the CASTLE or the SPY BOX at the start of the MATCH.
Is it supposed to say exceptions to A-E? Otherwise it seems to imply that ranking points from breaching defenses apply even if you are otherwise ineligible for ranking points.
The scouting! It never ends!
Unread 09-01-2016, 15:18
jrsmith jrsmith is offline
AKA: Jim
FRC #0339 (Kilroy Robotics)
jrsmith is an unknown quantity at this point
On page nine, is the tower flag confusing to others?
Unread 09-01-2016, 15:20
ATannahill ATannahill is offline
AKA: Alex Tannahill
Yes, I believe the flags are in the after capture configuration. Figure 1-1 and Figure 2-1 have the flag colors reversed.
Unread 09-01-2016, 20:25
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by MikLast View Post
... in fugure 2-1 the audience selected is in pos 2 and 4, ...
How does figure 2-1 show the position of the audience-selected defense? It shows all the defenses, and doesn't mention "audience" at all.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 09-01-2016, 20:42
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Figures 1-1 and 2-1 couldn't represent an actual game state, because in a real game the defense in the middle slot is same for both alliances. I don't think this is a mistake though--I think they just wanted to show all the different defenses in the same diagram, a configuration which isn't possible in a real match.
Page 100, 5.5.10.1 says that the audience selects Outer Works pos 3, and in figure 2-4, it shows pos 3 as in the center (of the 5 outer works spots) and in fugure 2-1 the audience selected is in pos 2 and 4, which is incorrect.
I'm not sure what you what you mean by saying the audience-selected defenses are in slots 2 and 4. The only distinguishing feature of the audience-selected defenses is that they're in the middle--how can you look at a static diagram and conclude that they're in the wrong place?
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 09-01-2016, 21:06
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Oh, i forgot to change this. I was corrected in another thread, i interpreted the second paragraph on 5.5.10.1 wrong.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
dibblec's Avatar
dibblec dibblec is offline
AKA: Mr. C
FRC #4824 (BerryBotics)
dibblec is an unknown quantity at this point
When looking at the fields in the manuals, the flags are opposite of what they are in the field tour videos here .
In the manual figure 2-1 is correct, the red flag is on the red alliance with the red secret passage, however, figures 2-2, 2-3, 2-4 and others the red and blue flags are on the opposite side of their alliance. It had some of our students confused at first until using figure 2-1 and compared that to the field tour videos.
If you look at them as being captured, then they are correct.
Unread 09-01-2016, 18:52
Paul Mace Paul Mace is offline
FRC #3024
Paul Mace is an unknown quantity at this point
dibblec: Yours is the definitive answer. Figs 1-1 and 2-1 are correct--the other illustrations are, well...misleading at best. The videos of the actual game field setup clearly show red alliance, red lights, red castle and red secret passage on one end and blue on the other. This also stands to reason from a game play and traditional design pattern--your human player is alongside your drive team.
See Figure 2-22, which clarifies everything.
Unread 09-01-2016, 21:41
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
A set of flags is on top of each TOWER: one red, one blue. Only one flag will be visible at a time. The
color of the displayed flag indicates ownership of the TOWER
The two flags appear to be on a mechanism that tilts them down as seen in figure 2-23. All of the drawings and pictures are in a correct state for the start of a match.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 10-01-2016, 12:40
z_beeblebrox's Avatar
z_beeblebrox z_beeblebrox is offline
Custom User Title
AKA: Cal
FRC #4183 (Bit Buckets)
z_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond reputez_beeblebrox has a reputation beyond repute
In R22, a space is missing between "floor" and "and".
R22 BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained
between two virtual horizontal planes, 4 in. above the floorand 12 in. above the floor, in reference to
the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
2012 Utah Regional Rookie All-Star
2013 Phoenix Regional Judge's Award for "design process and prototyping"
2014 Hub City Regional Quality Award, Arizona Regional Excellence in Engineering Award
2015 Arizona East Regional Creativity Award, Winner
2016 Arizona North Regional Finalist, Arizona West Excellence in Engineering Award, Finalist
Unread 10-01-2016, 21:43
AKA: Gerry
Originally Posted by Bochek View Post
... All of the drawings and pictures are in a correct state for the start of a match.
Figures 2-1 and 2-2 show opposite things, so they can't both be correct for the start of the match. Figs 2-1, 2-23, 2-24 show a reg flag on the tower near the red secret passage, which I believe is correct for start of match. Figs 2-2, 2-3, 2-4, 2-22, and 2-36 show a blue flag near the red secret passage, and red flag near the blue secret passage, which would only be correct if both towers have been captured.
Cal
Fairport, NY, USA
Unread 10-01-2016, 23:45
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Bochek is correct. Note that each figure that shows flag colors different from their corresponding Secret Passages are TOP views. From this perspective, you only see the flags that are in the DOWN position - the flags that are raised do not appear (or they only appear as a black line, i.e. the top edge of the raised flag)
[2002-2005]: FLL Coach
[2007-2010]: Mentor FRC 241
[2011-current]: Lead Advisor
FRC 3467 - The Windham Windup // 3467 on TBA
Windup Robotics 4-H Club
Unread 11-01-2016, 00:22
Purpose's Avatar
Purpose Purpose is offline
President
AKA: Victor A
FRC #0834 (Spartechs)
Rookie Year: 2015
Purpose will become famous soon enough
It's not quite a mistake, but the manual uses the phrase "undamaged defense" which is extremely vague, and the definition of "undamaged" is never given. Undamaged could be interpreted to mean crossed once, or crossed twice.
