Go to Post Chuck Norris can be the human player and throw a Poof ball into the 3 point goal and it counts. - Andy Baker [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.50 average. Display Modes
  #91   Spotlight this post!
Unread 09-01-2016, 14:53
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: FIRST STRONGHOLD Discussion
Originally Posted by Redo91 View Post
Check out 5.5.10 in the Game Manual, it has information regarding DEFENSES.
I have read this section, along with section 2.2.2.1. I am fairly confident in my first statement, but not the second. I looked through the figures in the manual and none have the defenses repeated.
  #92   Spotlight this post!
Unread 09-01-2016, 14:55
AKA: Alex Tannahill
Originally Posted by The Devinator View Post
Can a defense be broken in autonomous mode?
You should check page 31. A defense can be damaged (please use the correct term so that searches will pull this post up as a result in the future) if two different robots cross it in autonomous.
  #93   Spotlight this post!
Unread 09-01-2016, 14:56
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Section 3.1.3 of the Game Manual has the information you seek.
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #94   Spotlight this post!
Unread 09-01-2016, 15:02
Alex Webber Alex Webber is offline
Programming / Web Site / Scouting
FRC #1810 (Jaguar Robotics)
Rookie Year: 2015
Alex Webber is on a distinguished road
We had a quick question regarding the towers,
If the tower has been weakened to 0, if a robot shoots an additional Boulder at the tower, and it goes into a goal, does the alliance still gain points?
If the tower has been weakened, will the points from the balls still continue?
Thanks, and looking forward to this amazing game
Alex Webber | Co-Programming Lead and Scouting Lead
Jaguar Robotics FRC 1810
2015 | Greater Kansas City Regional 16/54
2016 | Greater Kansas City Imagery Award
2016 | Iowa Regional
  #95   Spotlight this post!
Unread 09-01-2016, 15:05
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
on the diagram on page 3, section 1.2 (same image is also on Page 8, section 2) , it shows the audience selected items one to the right of the center. On page 100 however (5.5.10.1) it says that it belongs in the center outer works spot. Am i correct in saying that the pictures in question are in error?
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #96   Spotlight this post!
Unread 09-01-2016, 15:09
AKA: Alex Tannahill
What diagram are you talking about? Can you give a figure number?
The audience selected item goes in slot 3, which is the center defense. Because of the secret passage, the center defense is not in the center of the field.
  #97   Spotlight this post!
Unread 09-01-2016, 15:12
MikLast's Avatar
CAO/Drive Coach
Figure 2-1. By center i mean the center of the 5 outer works, or spot 3. In Figure 2.1 it shows the audience selected one in Position 4/2.
  #98   Spotlight this post!
Unread 09-01-2016, 15:14
Redo91's Avatar
AKA: Justin
Double check section 3.1.4 and section 3.3.1 of the Game Manual.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #99   Spotlight this post!
Unread 09-01-2016, 15:15
Team5730-Pros Team5730-Pros is offline
FRC #5730
Team5730-Pros is an unknown quantity at this point
You can get points for crossing each defense twice because the defense is not damaged until the defense's strength is zero. You can only get points for crossing or weaken a defense once in auto.
Can you damage your own defense by using it to cross into the neutral zone instead of the secret passage, and if so can you find a rule that states this?
  #100   Spotlight this post!
Unread 09-01-2016, 15:17
AKA: Alex Tannahill
Figure 2.1. By center i mean the center of the 5 outer works, or spot 3. In Figure 2.1 it shows the audience selected one in Position 4/2.
FYI, the figure titles are hyphenated, I couldn't find it by using the find function and 2.1.
How do you know which ones are audience selected? The text does not tell you.
If I understand the audience selection process correctly than the same defense should be used on both sides, there is no defense repeated expect for the low bar.
  #101   Spotlight this post!
Redo91's Avatar
AKA: Justin
Figure 2-1 looks to just be a CAD rendering of the field with all the different DEFENSES installed.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #102   Spotlight this post!
Unread 09-01-2016, 15:19
AKA: Alex Tannahill
You cannot damage (successful crossing twice) a defense by moving from a courtyard into the neutral zone because the definition of crossing (pg. 31) requires you move the opposite direction.
  #103   Spotlight this post!
Unread 09-01-2016, 15:20
MikLast's Avatar
CAO/Drive Coach
The post will be edited to make sure people can find it.
Page 100, 5.5.10.1 says that the audience selects Outer Works pos 3, and in figure 2-4, it shows pos 3 as in the center (of the 5 outer works spots) and in fugure 2-1 the audience selected is in pos 2 and 4, which is incorrect.
  #104   Spotlight this post!
Harharhoman Harharhoman is offline
FRC #1094
Harharhoman is an unknown quantity at this point
For what I have found, the picture is wrong since the field tour video also said that it was the middle/center defense was chosen by the audience.
My question is how do they choose, is it a poll or measured in decibels?
  #105   Spotlight this post!
Unread 09-01-2016, 15:22
FRC #5730
can you damage your own defense if you go from the neutral zone into your own courtyard?
