Go to Post ..the way we see it FIRST isn't about winning a robot contest, its about trying your best to complete a really really hard task in a really really short amount of time. - Stuart [more]
Unread 09-01-2016, 13:28
FRC5442 FRC5442 is offline
FRC #5442
FRC5442 is an unknown quantity at this point
Secret Passage
According to the game manual you can enter the secret passage and have no time limit in said zone, but my question is when the opposing team rolls a ball into the secret passage. Can you steal the ball and then re-enter the courtyard to score some points? Thanks for helping me in advance!
~5442
Unread 09-01-2016, 14:05
Doug Frisk's Avatar
Doug Frisk Doug Frisk is offline
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
Re: Secret Passage
~5442
I read that rule several times.
G20 ROBOTS may only enter or exit their opponent’s SECRET PASSAGE from/to the opponent’s COURTYARD. A ROBOT is considered to be within the SECRET PASSAGE once the only carpet the ROBOT is in contact with is the carpet inside the SECRET PASSAGE.
My reading of that is that if you've made it through the defenses and are in their courtyard you can occupy the space that is the secret passage.
You must exit the secret passage back into the opponent's courtyard as well.
So, once you are in the courtyard, you can enter the secret passage to snag balls as they are entering the field.
Unread 09-01-2016, 14:16
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
Re: Secret Passage
Yes, my interpretation of that was basically that you CAN cross from the opponent's courtyard into their secret passage (and vice versa), but you CANNOT cross from the neutral zone into their secret passage (and vice versa). Ever.
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 09-01-2016, 14:27
MikLast's Avatar
MikLast MikLast is online now
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
Re: Secret Passage
some people on the team seem to be confused on this explanation, but wont explain what they are confused on (thanks Jermery) can you explain this a little more in-depth for us? i'd love to tell you what they dont understand but they wont explain. (tensions are a little high here...)
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2016, 14:29
Re: Secret Passage
I'll put it this way: You cannot use the Secret Passage to bypass your opponents' Defenses. You can use it to get around your own, however.
Once you are inside the defenses, you can enter but not use the passage.
Unread 09-01-2016, 14:32
MikLast's Avatar
CAO/Drive Coach
Re: Secret Passage
That explained it. Thanks a ton!
Unread 09-01-2016, 14:38
bvisness's Avatar
Re: Secret Passage
I like that explanation. Good intuitive sense of what the rule is saying.
Here's a picture (NOT from the manual):
Last edited by bvisness : 09-01-2016 at 14:42. Reason: Smaller picture, clarification
Unread 09-01-2016, 14:42
MikLast's Avatar
CAO/Drive Coach
Re: Secret Passage
Here's a picture:
one more question, does the yes on entering your side go with entering apply to the enemy secret passage?
Unread 09-01-2016, 14:43
bvisness's Avatar
Re: Secret Passage
I'm not quite sure what you're asking, but you are always free to enter and exit YOUR secret passage from any direction.
This picture was made assuming you were on the blue alliance.
Unread 09-01-2016, 14:52
MikLast's Avatar
CAO/Drive Coach
Re: Secret Passage
you answered the question. thank you.
Unread 09-01-2016, 15:05
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Secret Passage
If it's ok to sit inside your opponent's secret passage, is it not possible to block [s]cannonballs[/s] boulders from entering the field indefinitely? I could not find mention of this in the manual, and it feels like I'm missing something.
EDIT: I can;t get strikethrough to work. Boulders, not canonballs. I'm too used to the pre-season speculation.
Unread 09-01-2016, 15:07
ATannahill ATannahill is online now
AKA: Alex Tannahill
Re: Secret Passage
Originally Posted by asid61 View Post
If it's ok to sit inside your opponent's secret passage, is it not possible to block cannonballs from entering the field indefinitely? I could not find mention of this in the manual, and it feels like I'm missing something.
Boulders (please use the official term, there are no such thing as cannonballs in FIRST Stronghold) need to be returned to the field if there are more than 6 in the castle. I see no rules about intercepting incoming boulders.
Unread 09-01-2016, 15:29
dubiousSwain's Avatar
dubiousSwain dubiousSwain is offline
The ride never ends
AKA: Christian Steward
FRC #5420 (Velocity)
dubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond reputedubiousSwain has a reputation beyond repute
Re: Secret Passage
Handy diagram (now featuring both sides of the field)
From the perspective of the red team.
Name:	feeld diagram.png
2015 MAR District Champions
Unread 09-01-2016, 15:34
gbear605's Avatar
gbear605 gbear605 is offline
Scarebear
FRC #1768 (Nashoba Robotics)
gbear605 is an unknown quantity at this point
Re: Secret Passage
I believe that intercepting and hoarding more than one would count as a violation of G38.
Unread 09-01-2016, 15:37
AKA: Alex Tannahill
Re: Secret Passage
I would agree, if you try to control multiple. If you simply redirect them into your opponent's courtyard one at a time, I do not see a problem with G38.
