Go to Post FRANK, YOU'RE THE MAN. - Libby K [more]
Thread Tools Rating: Thread Rating: 6 votes, 4.50 average. Display Modes
  #136   Spotlight this post!
Unread 09-01-2016, 16:34
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Re: FIRST STRONGHOLD Discussion
Originally Posted by Hugekase View Post
I am still really confused on the whole spy thing, it seems like a not needed thing, and if you move it out of it's area, you could get fouled on it, whats the point of it?
Are you confused on the Spy Box, the Spy Bot, or both?
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
  #137   Spotlight this post!
Bentorino's Avatar
Bentorino Bentorino is offline
Bentorino
FRC #1983 (Stinkwerkz)
Team Role: Operator
Bentorino is an unknown quantity at this point
Originally Posted by EricLeifermann View Post
Anybody else notice 1 boulder is $35.00 from andymark?!?!? Seems crazy expensive, or did I read the description wrong and you get more than 1?
Gopher balls are pretty expensive! If you want just the same balls, you can buy the rainbow set, but it won't be FIRST branded.
Set of 6 is going for around $200: http://www.gophersport.com/pe/premiu...gaAv3l8P8 HAQ
  #138   Spotlight this post!
EricH EricH is online now
There are two spies.
Spy BOX: Place where a human stands (Driver or Human Player). They act as an extra set of eyes.
Spy BOT: Robot that starts in the Courtyard. No difference from any other robot on the alliance other than starting location.
  #139   Spotlight this post!
Unread 09-01-2016, 16:35
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Ok, so on the line of that, so the spy bot can not be controlled once in the box, only in the round?
And, on the other hand, what is the advantage of having the spy bot? Is it required?
The issue seems to be that SPY is not defined in the GLOSSARY. If you check out the definition of SPY BOX, though, it is located outside the FIELD. Rule G9 then discusses the occupant of the SPY BOX.Check out rule G7, it talks about the "spy bot".
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #140   Spotlight this post!
Unread 09-01-2016, 16:36
Redo91's Avatar
AKA: Justin
Originally Posted by Bentorino View Post
Gopher balls are pretty expensive! If you want just the same dimensinos and firmness you can buy the rainbow set, but it won't be FIRST branded.
Set of 6 is going for around $80: http://www.gophersport.com/pe/premiu...gaAv3l8P8 HAQ
Make sure you have the correct diameter selected, the 10 inch set is $205.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
  #141   Spotlight this post!
Unread 09-01-2016, 16:38
michchinn michchinn is offline
FRC #5404 (Gearaffes)
Team Role: CAD
michchinn is an unknown quantity at this point
Check your diameter. The 10” balls on the website you attached are $205 for a set of 6. It is $80 only for the 6.3” diameter balls.
The Heart Attackers/WMS Blue (FLL) 2010 - 2013
341 Miss Daisy (FRC) 2013 - 2015
5404 The Gearaffes (FRC) 2015 -
  #142   Spotlight this post!
Unread 09-01-2016, 16:40
Hugekase Hugekase is offline
FRC #1359 (Scalawags)
Team Role: Student
Hugekase is an unknown quantity at this point
Alright, this makes a lot more sense about the spy, now then, what about the secret passage, where is the exact rules on it, and if the same team can bypass the defenses on there side.
  #143   Spotlight this post!
Unread 09-01-2016, 16:43
ATannahill ATannahill is offline
AKA: Alex Tannahill
What are you thoughts? Open the pdf of the manual and use the find function to search for secret passage.
  #144   Spotlight this post!
H78 H78 is offline
H78 is an unknown quantity at this point
Does anyone know if the Q&A system is open, or when it opens if it isn't yet? How do you ask a question, when it's open?
  #145   Spotlight this post!
Unread 09-01-2016, 16:44
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by DWCEagles228 View Post
Refree job is hell even more
Naah, just give me an decibel measuring app.
Although I suspect we will be busy scoring points for CROSSINGS.
(since 2004)
  #146   Spotlight this post!
Unread 09-01-2016, 16:45
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by jajabinx124 View Post
I think it's just blue HDPE... it better be HDPE..
He had to take his shoes off ....
(since 2004)
  #147   Spotlight this post!
Unread 09-01-2016, 16:47
It is not open. It's not open to try to force everybody to actually read the Manual.
It should open up mid-week--tradition is that it opens on the first Wednesday of build season, AFTER Team Update #1 comes out on Tuesday.
And when it's open, they'll have a message out on how to use it.
  #148   Spotlight this post!
Unread 09-01-2016, 16:48
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by MikLast View Post
For rule G22, would it be considered pinning if a robot was to inhibit forward motion while the opposing robot was in an defense?
For example, if the opposing robot was trying to move past one of the barriers and blocked forward motion into our side, would that be considered pinning?
Past interpretations have been that if a robot has a path out, it's not a pin. You have to contact the robot and prevent it from moving for it to be a pin.
(since 2004)
  #149   Spotlight this post!
Unread 09-01-2016, 16:53
However, there is another rule that could be in play. If they're heading to or from your Courtyard, and you interfere, there's a foul for that.
  #150   Spotlight this post!
Unread 09-01-2016, 17:30
picklecrackers picklecrackers is offline
FRC #2990
picklecrackers is an unknown quantity at this point
Lightbulb Re: FIRST STRONGHOLD Discussion
Has anyone found anything regarding how the boulders must be rolled into the secret passages? Do they have to be entered using a bowling-type fashion?
