Go to Post "Is it possible to cut enough holes in the robot to weight reduce 8 lbs?" - ScoutingNerd175 [more]
Unread 09-01-2016, 17:27
andrew_103 andrew_103 is offline
FRC #0691
andrew_103 is an unknown quantity at this point
Tower Damage During Autonomous
Has anyone found in the 2016 game manual clear evidence that the tower gets damaged when boulders are shot into it during autonomous?
Unread 09-01-2016, 17:30
Redo91's Avatar
Redo91 Redo91 is offline
AKA: Justin
Redo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of lightRedo91 is a glorious beacon of light
Re: Tower Damage During Autonomous
This is addressed in section 3.1.4 of the Game Manual
Team 1296-Full Metal Jackets
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 09-01-2016, 17:40
FRC #0691
So then yes it is damaged? That section doesn't specify specifically that its damaged in autonomous also like it specifies that defenses aren't damaged. That's why I'm asking.
Unread 09-01-2016, 18:23
Redo91's Avatar
AKA: Justin
My reading of the second paragraph is that any BOULDER scored damages the TOWER, regardless of the game period.
I have not seen in the rules where it states that DEFENSES can not be damaged in Auto. Where is this information in the Game Manual?
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 09-01-2016, 18:31
FRC #0691
On page 4 in the manual, it talks about how you can score during autonomous by shooting into the tower but doesnt specify if the tower is damaged or not. However, right after when the manual explains teleop scoring, it mentions that the tower is damaged once scored on bringing one to think that the lack of mentioning it might mean that it won't be damaged during autonomous.
Unread 09-01-2016, 18:33
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I believe at all times both the towers and the defense can be damaged.
The only special case is that in Auto 1 robot can on cause 1 strength worth of damage to a defense.
Still re-reading though. that's how I read it right now
Unread 09-01-2016, 18:37
Redo91's Avatar
AKA: Justin
Read section 3.1.4 again and tell me what you think after that.
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 09-01-2016, 18:41
FRC #0691
Well I have but with the other information on page 4 it all confuses me. It seems like it would be damaged but the lack of specifying this in the game manual is making me doubt this.
Unread 09-01-2016, 18:47
Redo91's Avatar
AKA: Justin
What page 4 are you referring to?
The second sentence of the second paragraph in section 3.1.4 is still leaving you confused?
Alumni 2009
Mentor 2009-2014
Team 624-CRyptonite
Mentor 2014-2015
Unread 09-01-2016, 18:51
FRC #0691
Oh im sorry I didn't specify. I was referring to page 4 of the overall document, not a specific section
Unread 10-01-2016, 09:15
GaryVoshol's Avatar
Cogito ergo arbitro
You mean on the page that starts with
1.3 Description
Full game play details may be found in later sections of this manual.
Note that first sentence. Section 1 is just a general description. Follow the details later in the manual if there are any discrepancies.
I do see where you were misled, as the text following Table 1-1 is talking about decreasing TOWER STRENGTH during Teleop. But again, that's just a general description, not a definition.
(since 2004)
