Go to Post Friction is finicky. - Ether [more]
Unread 09-01-2016, 17:50
andrew_103 andrew_103 is offline
FRC #0691
andrew_103 is an unknown quantity at this point
Re: Spy and Spybot
Yea my team is having a similar discussion as to the usefulness of having a spybot and what advantages it would yield.
Unread 09-01-2016, 17:55
Brandon3130 Brandon3130 is offline
FRC #3130
Brandon3130 is an unknown quantity at this point
Re: Spy and Spybot
One use could be to feed boulders to an offensive, shooter-only bot that started in the spy position. Te bot could also hold open the group C defense if need be.
Unread 09-01-2016, 17:59
dirtbikerxz's Avatar
dirtbikerxz dirtbikerxz is offline
Captain | Driver | CAD | Junior
AKA: Rohit Gondi
FRC #3991 (KnightVision)
Team Role: Driver
Rookie Year: 2015
dirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud ofdirtbikerxz has much to be proud of
Re: Spy and Spybot
Remember you cant push boulders over the defenses, you actually have to pick it up and have control of it (max one at a time), before you can take it to the other side, or it will be a foul.
Unread 09-01-2016, 18:01
Re: Spy and Spybot
[Citation needed]
Take a good look at G40 again. Particularly the blue box, first section, B paragraph.
You can push them over, but you have to be in control of them all the way through and finish crossing yourself.
Unread 09-01-2016, 18:03
AKA: Rohit Gondi
Team Role: Driver
Rookie Year: 2015
Re: Spy and Spybot
[Citation needed]
Ah yes i see that, didn't read it right the first time. But still basically the same concept ... almost .
