Go to Post Team 1114 does not design or build ROBOTS. They build AWESOME. - DonRotolo [more]
Unread 09-01-2016, 18:23
based_toat_goat based_toat_goat is offline
FRC #4915
based_toat_goat is an unknown quantity at this point
Scaled Robots after round?
Does the robot need to continue hanging after it is powered off, or can it coast down the tower wall? Thanks.
Unread 09-01-2016, 18:26
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Re: Scaled Robots after round?
The final judgement by the referee as to if the robot has scaled the castle will be made 5 seconds after the end of tele. So yes, it has to be able to hold its self up.
Unread 09-01-2016, 18:31
FRC #4915
What are the rules on getting it back down? Can you turn a robot back on in order to lower it?
Unread 09-01-2016, 18:33
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Not sure. I'm assuming you can't turn your robot back on because the Game Manual clearly says you can't re-enable to get boulders out.
Unread 09-01-2016, 18:34
No. You can't power up/tether up a robot after the match. You'll have to lift it off somehow. How exactly you get it off is left as an exercise to the designer.
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
Read the manual carefully!
Originally Posted by Section 3.3.1 Point Values
The final assessment of ROBOTS having SCALED or CHALLENGED the TOWER is made five (5) seconds after the ARENA timer displays zero (0), or when all ROBOTS have come to rest following the conclusion of the MATCH, whichever happens first.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
FRC #4915
Alright thanks.
Unread 09-01-2016, 18:57
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
You can't power a motor, but you can vent pneumatics or switch the position of a solenoid.
Unread 09-01-2016, 22:08
Irwin772's Avatar
Irwin772 Irwin772 is offline
AKA: Ian Koscielski
no team (FIRST Robotics Canada)
Irwin772 is a glorious beacon of lightIrwin772 is a glorious beacon of lightIrwin772 is a glorious beacon of lightIrwin772 is a glorious beacon of lightIrwin772 is a glorious beacon of light
The height that the robot must reach for a scale is only 2 feet off the ground. There should be no issues with getting robots down from there. The same as 2010 when robots were hanging in the end game.
Member Team 772: 2007-2011
Mentor Team 772: 2011- 2012, 2016
Mentor Team 4069: 2012-2015
FIRST Team Recruitment/Training Coordinator - British Columbia 2016-????
Team 772
2012 Smoky Mountain Regional Champions with 234 and 3259
Team 4069
2013 Waterloo Regional Champions with 2056 and 1114
2014 North Bay Regional Finalists with 4476 and 5191
