Go to Post Because the new control system weights as much as a fully-loaded M1 Abrams Tank. - artdutra04 [more]
Unread 09-01-2016, 13:39
SPORK_Guy's Avatar
SPORK_Guy SPORK_Guy is offline
Team SPORK Captain
AKA: Jacob Ferrier
FRC #3196 (Team SPORK)
SPORK_Guy is an unknown quantity at this point
Post Flying?
So, we are searching for a rule in the manual that specifically forbids creating a robot that has the ability to fly....my better judgement says that this is a bad idea, but I cannot find a rule against it. If you have found a rule please let me know, for it could change our entire design
Unread 09-01-2016, 13:41
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: Flying?
The closest I have seen is G45.
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Re: Flying?
Rule G17 says the robot cant be higher than 4ft 6in, may be it hard to keep within that.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2016, 13:44
AKA: Alex Tannahill
Re: Flying?
Read the blue box of G17.
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Flying?
One could interpret G17 as not allowing it, but then it does allow for angling and the like...
interesting observation. Given the nature of the game and the new availibility of the 775pro, I could see an ultralight robot being made to fly. It would probably draw too much current though, especially given the weight of the battery and control system.
EDIT: just ran some quick numbers. You would need many, many 775pros to do anything. Each motor produces perhaps 1.4-3lbs of thrust, 1.6lbs of which goes to the weight of the motor itself (which weighs 0.8lbs, leaving between -0.2 and 1.4lbs thrust for the other parts of the robot. Chassis + battery + control system will run at least 30lbs, so you will need at minimum 21 775pros, not including any manipulators you might want to attach.
Unread 09-01-2016, 16:34
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Flying?
You'd need to fly low if you want to score points for CROSSING the DEFENSES.
(since 2004)
Unread 09-01-2016, 16:35
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: Flying?
Good luck making a robot fly with the 13 lb battery we use.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 09-01-2016, 16:36
AKA: Alex Tannahill
Re: Flying?
How do you figure? The requirement is to "traverses the DEFENSE such that its BUMPERS go fully between the adjacent SHIELDS/GUARDRAIL". The outer works have infinite height.
Unread 09-01-2016, 16:42
ice.berg's Avatar
ice.berg ice.berg is offline
Strategy Mentor &amp; Drive Team Coach
AKA: Alex Bergal
ice.berg has a spectacular aura aboutice.berg has a spectacular aura about
Re: Flying?
plus bumpers and control system!
TEAM 2512 DULUTH EAST DAREDEVILS
'12-'15: Strategy and Build Mentor
'15 Hopper Division Champions and Einstein Finalists thanks 987, 2826, 4265
'15 Minnesota State Champions thanks 3130 and 4215
'15 Northern Lights Chairmans Winner and Regional Finalists & Central Illinois Regional Finalists
'10-'11:Build Captain
'13 Midwest Champion '12 North Star Champion '11 Lake Superior Champion
Website Facebook Twitter Youtube Flickr
Unread 09-01-2016, 17:08
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: Flying?
G44 ... a ROBOT “leapfrogging” or “spider climbing” across a DEFENSE by applying force to the SHIELDS and lifting itself over the DEFENSE is a
violation of this rule
Leapfrogging is pretty much temporarily flying. It's mentioned in the rules, and pretty much says if you do it, do it without putting pressure on the defense shields. Just a thought.
Unread 09-01-2016, 17:09
greekfire100's Avatar
greekfire100 greekfire100 is offline
AKA: Cool Kid #0010
FRC #5476 (Y-Bridge Robotics)
Team Role: Scout
greekfire100 is an unknown quantity at this point
Thumbs up Re: Flying?
I see no rule against it, and I say if you can find a way to create a flying robot with the parameters given, more power to you
Unread 09-01-2016, 17:12
Re: Flying?
Also,
G17 ROBOT height, as measured when it’s resting normally on a flat floor, may not exceed 4 ft. 6 in. This is saying that one edge/corner of the robot can be more than 4'6" off the ground, as long as the height of the robot doesn't exceed 4'6". This is also shown in the rule diagram.
Unread 09-01-2016, 17:13
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Flying?
See the sub-section on "Shields" in part 2 of the manual - they're only 2 feet tall.
(since 2004)
Unread 09-01-2016, 18:43
Xanawatt Xanawatt is offline
FRC #1024
Xanawatt is an unknown quantity at this point
Re: Flying?
Originally Posted by AndyBare View Post
Also,
He's got a point. The rules do allow for that this year!
Unread 09-01-2016, 18:50
BotDesigner's Avatar
BotDesigner BotDesigner is offline
Design/CAD/Strategy/TeamManagement
AKA: David Gedney
FRC #4418 (Team Impulse)
BotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud ofBotDesigner has much to be proud of
Re: Flying?
Yeah, lets just let 148 work that one out, it would be a nice successor to Tumbleweed.
