Re: Thoughts on team strategy?
Any boulder scoring robot is going to have to breach at least 1 of the categories as they need to pass the defenses to get into the opponents' courtyard. Save yourself the trouble and only work on breaching 2-3 categories. Then spend your extra time scoring in the low goal, defending, etc.
Would you think that a 6 wheeled drivetrain with 2 bogey wheels be a good idea for pushing another robot for defense but also traversing the rock terrain?
What do you think about shooting?
that will be extremely hard to do unless you have a good vision system
What do you guys think about a 6 wheel drivetrain? Also do you have a plan on defending the shooters?
#7
I can see a lot robots this season using 6 wheel drivetrain, our team might consider using them ourselves, and best way to play defense for a shooting bot is to disrupt the aiming and shot.
#8
Would you recommend trying to put a shield up? And do you see any issues with the 6 wheel drive?
#9
You can try to implement a shield could do the job, but what we found that a nudge or bump of a team out of position is just as effective. Good driving practice is a good form defense. There can be issue of tipping with any drivetrain it depends on how high your center of gravity.
#10
if you go offensive you could design it more compact to go through the lowbar (which is a very strategic component for an alliance), and be able to gather boulders somehow, to shoot in the low goals. If your going more defensive, try a faster and taller robot to block the boulders like http://imagecache2.allposters.com/im...POD/147605.jpg
as an example, to block shots both on top and bottom, but it can't be top heavy. |
#11
