Go to Post In theory, there is no difference between theory and practice. In practice, however... - Alan Anderson [more]
Unread 09-01-2016, 19:47
Matt10010010010 Matt10010010010 is offline
AKA: Matthew Rogers
FRC #2465 (Kaua'ibots)
Matt10010010010 has a little shameless behaviour in the past
Kick the ball.
Is it possible to kick the ball through the secret passage?
Unread 09-01-2016, 19:50
JonA1557 JonA1557 is offline
FRC #1557
JonA1557 is an unknown quantity at this point
Re: Kick the ball.
it may not be as effective as going on the floor and punching the ball, with more power and accurecy
Unread 09-01-2016, 20:22
AndyBare AndyBare is online now
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: Kick the ball.
You can for your secret passage, but
G27 states: A ROBOT may not transfer BOULDERS from the NEUTRAL ZONE to the opponent’s SECRET PASSAGE.
Violation: TECH FOUL per BOULDER
So that rules out kicking a ball through the opposing alliance's secret passage from the neutral zone. I suppose you can kick it backwards, but that would be very counterproductive.
Unread 09-01-2016, 21:45
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Re: Kick the ball.
Your not allowed to move the ball through to the opponents Courtyard in any way shape or form without carrying or following the ball into the opponents zone and then backing back into the neutral zone. Just lobbing balls results in tech fouls.
Unread 09-01-2016, 23:23
kingbrandon14's Avatar
kingbrandon14 kingbrandon14 is offline
FRC 4188 Engineering Mentor
AKA: Brandon King
FRC #4188 (Columbus Space Program)
kingbrandon14 will become famous soon enough
Re: Kick the ball.
Would it be legal to pick up a boulder from midfield and roll it through one of the defenses to your alliance partner for them to pick it up and score it?
2012 Peachtree Regional Rookie All-Star; 2015 Peachtree Regional Winner; 2016 PCH District Columbus Winner, Albany Finalist & EI; 2016 Rocket City Regional Finalist, Wildcard
Unread 09-01-2016, 23:27
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Kick the ball.
See G40.
Unread 09-01-2016, 23:28
dmaggio744's Avatar
dmaggio744 dmaggio744 is offline
Sleeping CNC Operator
AKA: Drew Maggio
FRC #2869 (Regal Eagles)
Rookie Year: 2015
dmaggio744 is an unknown quantity at this point
Re: Kick the ball.
G40: A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER
WORKS into the NEUTRAL ZONE)
Once you move the boulder into the opponent's courtyard, another robot can take control of the boulder, but your robot must both come in contact with the boulder in the outer works, and pass through the defense. So you cant nudge one through, but I see no harm in giving it to another bot as long as your robot went through the defense.
Hope this helped
Unread 09-01-2016, 23:37
Christopher149 Christopher149 is offline
FRC #0857 (Superior Roboworks) FTC 10723 (SnowBots)
Christopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond reputeChristopher149 has a reputation beyond repute
Re: Kick the ball.
I at least think the OP was referring to a Human Player kicking the ball through the Embrasure to return it to play instead instead of bowling it.
I see no reason or rule why not, other than bowling might be easier.
2015-present: FTC 10723 mentor
2012-present: 857 mentor
2008-2011: 857 student
2015: Industrial Design, Excellence in Engineering, District Finalist, Archimedes Division (#6 alliance captain)
2014: Judges Award, District Engineering Inspiration, District Finalist, Galileo Division
Unread 10-01-2016, 00:00
Dt33345 Dt33345 is offline
FRC #3512
Team Role: Marketing
Rookie Year: 2016
Dt33345 is an unknown quantity at this point
Re: Kick the ball.
The only problem I could think of from kicking the boulders is the ball could pick up and carry over the defenses. If a team finds a member that can kick the boulders in the right way then they won't have to send bots back to move boulders across the defenses.
Unread 10-01-2016, 00:19
mackenzieg's Avatar
mackenzieg mackenzieg is offline
AKA: Mackenzie Glaser
mackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of lightmackenzieg is a glorious beacon of light
Re: Kick the ball.
This is actually something my team talked about for a little while today. There don't seem to be any rules prohibiting kicking the boulder as opposed to just rolling it, it just depends on whether you would rather it to go further down the field or be aimed more accurately.
The fact that the low bar is right in front of the SP makes it seem pretty likely that with enough power it would bounce over into the courtyard or out of the field entirely. G40 essentially says that robots can't cause boulders to move from the neutral zone to the opponent's courtyard without being in contact with them and crossing as well, but doesn't say anything about human players. The refs probably wouldn't be thrilled with that strategy, but I can't find anything prohibiting it (unless I'm missing something).
______________
Mackenzie Glaser
Robo Lions 1261
Unread 10-01-2016, 00:42
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Re: Kick the ball.
As previously mentioned, I don't see a rule prohibiting it now, but it will probably be disallowed in a Q and A or manual update pretty soon. I don't think that's within the spirit or nature of the game, so I couldn't imagine them wanting to allow it.
Unread 10-01-2016, 00:44
FRC #3512
Rookie Year: 2016
Re: Kick the ball.
I don't think it would bounce out with enough control. Foam dodgeballs like the boulders pick up and slow down easy so it should be easy to kick it right so it gets past the defenses and just drops.
Unread 10-01-2016, 08:47
Michael Hill's Avatar
Re: Kick the ball.
COURTYARD unless:
Hope this helped
That rule applies to ROBOTS causing the boulder to move from the neutral zone to the opposing alliance's courtyard, not HUMAN PLAYERS.
Unread 10-01-2016, 11:17
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Re: Kick the ball.
COURTYARD unless:
In other words, toasters with collectors are a very, very valuable asset. Imagine this- a kitbot drivetrain, with a basic external collector, just some polycord on a tube, spinning on the front of the bot. If that can hold a ball, go through the low bar, and back out, you've just put a ball in position for a shooter to score it very conveniently. I have a feeling cheesecake will be making a return.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-01-2016, 11:37
paulschonfeld's Avatar
paulschonfeld paulschonfeld is offline
FRC #4230 (TopperBots)
paulschonfeld is an unknown quantity at this point
Re: Kick the ball.
The 2016 FIRST Field Tour Video makes reference to how the feeder stations and how they are intended to be used.
One quote from the video is:
"It is imperative for your own safety that you don't reach through these openings, even a little bit. The embrasure is a tight fit for the boulders, so your human player will need accurate bowling skills."
My interpretation of the quote from the video is that FIRST will not want or allow human players to kick the ball through the openings if there is a possibility that their foot could 'reach through' one of the openings, for safety reasons.
TopperBots
Team 4230 :: Duluth, MN :: topperbots4230.com
Last edited by paulschonfeld : 10-01-2016 at 11:38. Reason: wanted to include link to team website and information
