Go to Post resist the hive: As goofy as this may sound, wires do take up weight, several pounds of it. - Rickertsen2 [more]
Unread 09-01-2016, 13:30
AMendenhall AMendenhall is offline
FRC #3925
AMendenhall is an unknown quantity at this point
FIRST 2016 Game Manual Mistakes
Page 15 of the 2016 Game Manual:
"The Rough Terrain is constructed from thirty (31) pieces..."
Pretty sure there are 31 pieces on the rough terrain.
Unread 09-01-2016, 13:31
ATannahill ATannahill is offline
AKA: Alex Tannahill
Re: FIRST 2016 Game Manual Mistakes
Table 5-2, fourth column, ninth row, the 2 is not formatted as a superscript.
Unread 09-01-2016, 13:36
CPR fan CPR fan is offline
FRC #3663
CPR fan is an unknown quantity at this point
The word practice is misspelled as "pratice" on page 101 in the second paragraph of the blue box.
Unread 09-01-2016, 14:28
2791GreenFlare 2791GreenFlare is offline
FRC #2791
2791GreenFlare is an unknown quantity at this point
Exclamation Re: FIRST 2016 Game Manual Mistakes
One error in the obstacle of the moat was that the depth of the moat is 2 inches not 2 feet. 2 feet is statistically impossible so it only makes sense to be 2 inches.
Unread 09-01-2016, 14:30
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
I already answered this at your other thread, but this is NOT an error because the "depth" in the manual is referring to the distance across the moat.
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 09-01-2016, 14:40
Anteprefix's Avatar
Anteprefix Anteprefix is online now
FRC #1678 (Citrus Circuits)
Anteprefix is on a distinguished road
Section 5.3.3 Ranking Score says
Ranking Points are units credited to a Team based on their ALLIANCES’ performance in Qualification
MATCHES. Ranking Points are awarded to each eligible Team at the completion of each Qualification
MATCH:
A. Each Team on the winning ALLIANCE receives two (2) Ranking Points.
B. Each Team on the losing ALLIANCE receives zero (0) Ranking Points.
C. In the event of a tied score, all Teams receive one (1) Ranking Point.
D. Each Team on an ALLIANCE that CAPTURES a TOWER receives one (1) Ranking Point.
E. Each Team on an ALLIANCE that BREACHES the OUTER WORKS receives one (1) Ranking
Point.
Exceptions to A-D are as follows:
F. A SURROGATE receives zero (0) Ranking Points.
G. A DISQUALIFIED Team, as determined by the Head REFEREE, receives zero (0) Ranking
Points in a Qualification MATCH or causes their ALLIANCE to receive zero (0) MATCH points
in a Playoff MATCH.
H. A “no-show” Team is DISQUALIFIED from that MATCH. A Team is declared a no-show if no
member of the DRIVE TEAM is in the CASTLE or the SPY BOX at the start of the MATCH.
Is it supposed to say exceptions to A-E? Otherwise it seems to imply that ranking points from breaching defenses apply even if you are otherwise ineligible for ranking points.
The scouting! It never ends!
Unread 09-01-2016, 15:18
jrsmith jrsmith is offline
AKA: Jim
FRC #0339 (Kilroy Robotics)
jrsmith is an unknown quantity at this point
On page nine, is the tower flag confusing to others?
Unread 09-01-2016, 15:20
dibblec's Avatar
dibblec dibblec is offline
AKA: Mr. C
FRC #4824 (BerryBotics)
dibblec is an unknown quantity at this point
When looking at the fields in the manuals, the flags are opposite of what they are in the field tour videos here .
In the manual figure 2-1 is correct, the red flag is on the red alliance with the red secret passage, however, figures 2-2, 2-3, 2-4 and others the red and blue flags are on the opposite side of their alliance. It had some of our students confused at first until using figure 2-1 and compared that to the field tour videos.
If you look at them as being captured, then they are correct.
AKA: Alex Tannahill
Yes, I believe the flags are in the after capture configuration. Figure 1-1 and Figure 2-1 have the flag colors reversed.
Unread 09-01-2016, 18:52
Paul Mace Paul Mace is offline
FRC #3024
Paul Mace is an unknown quantity at this point
dibblec: Yours is the definitive answer. Figs 1-1 and 2-1 are correct--the other illustrations are, well...misleading at best. The videos of the actual game field setup clearly show red alliance, red lights, red castle and red secret passage on one end and blue on the other. This also stands to reason from a game play and traditional design pattern--your human player is alongside your drive team.
See Figure 2-22, which clarifies everything.
Unread 09-01-2016, 19:57
Orthofort's Avatar
Orthofort Orthofort is offline
FRC #2832
Orthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to allOrthofort is a name known to all
Just to add on to this, it looks like it is Figures 2-2, 2-3, 2-4, 2-22, and 2-36 which have the flags reversed. I'm guessing they just just screwed up on one and copied the same image for the others, since all the figures are just variations on the same picture, since all of the other figures which contain different images are correct.
Unread 09-01-2016, 20:25
Cal578 Cal578 is offline
Passionate FIRST-er, CD donor
AKA: Gerry
FRC #0578 (Red Raider Robotics)
Cal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant futureCal578 has a brilliant future
Originally Posted by MikLast View Post
... in fugure 2-1 the audience selected is in pos 2 and 4, ...
How does figure 2-1 show the position of the audience-selected defense? It shows all the defenses, and doesn't mention "audience" at all.
Cal
R3: Red Raider Robotics (FRC Team 578)
Fairport, NY, USA
www.FairportRobotics.org
2016 Finger Lakes Regional: Semifinalist on Alliance 7 (1128, 2010, 578)
2016 NYC Regional: Finalist on Alliance 3 (3419, 578, 3017), 4th seed team, Team Spirit Award
2015 Finger Lakes Regional: 8-3-0 in qualification, 7th seed, Quarterfinalist
2014 NY Tech Valley Regional: 8-4-0 in qualification, 13th seed, Semifinalist
2013 Finger Lakes Regional: 4-5-0 in qualification, 26th seed, Alliance 6, 1-2 in tournament
2012 Buckeye Regional: Gracious Professionalism Award, 7-3-0, 14th seed
2011 Finger Lakes Regional: Engineering Inspiration Award
Unread 09-01-2016, 20:42
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
Figures 1-1 and 2-1 couldn't represent an actual game state, because in a real game the defense in the middle slot is same for both alliances. I don't think this is a mistake though--I think they just wanted to show all the different defenses in the same diagram, a configuration which isn't possible in a real match.
Page 100, 5.5.10.1 says that the audience selects Outer Works pos 3, and in figure 2-4, it shows pos 3 as in the center (of the 5 outer works spots) and in fugure 2-1 the audience selected is in pos 2 and 4, which is incorrect.
I'm not sure what you what you mean by saying the audience-selected defenses are in slots 2 and 4. The only distinguishing feature of the audience-selected defenses is that they're in the middle--how can you look at a static diagram and conclude that they're in the wrong place?
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
Unread 09-01-2016, 20:50
Brad Hanel's Avatar
Brad Hanel Brad Hanel is offline
Sharpie Thief
AKA: B
Brad Hanel is on a distinguished road
I feel as though calling "depth" anything but the "deepness" when referring to a body of water is a little confusing.
Unread 09-01-2016, 21:06
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Oh, i forgot to change this. I was corrected in another thread, i interpreted the second paragraph on 5.5.10.1 wrong.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
