Go to Post If you have to build the best robot to be inspired then we end up with one winning inspired team, and 999 losers. That is not the spirit of FIRST. - KenWittlief [more]
Unread 09-01-2016, 19:05
amesmich's Avatar
amesmich amesmich is online now
FRC #4638 (Jagbots)
amesmich is an unknown quantity at this point
Re: Flying?
So long as the top of your bumpers are not more than 12" from the floor..... Rules out the advantage of flying.
Unread 09-01-2016, 19:24
pilleya's Avatar
pilleya pilleya is offline
Elec+Mech
AKA: Alastair Pilley
FRC #4613 (Barker Redbacks)
pilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond reputepilleya has a reputation beyond repute
Re: Flying?
The amount of thrust needed to lift the the control system+battery, would be greater than the current the battery can provide, even without the fuses and main breaker being a problem. Lifting even the minimum components would require at least 10kw+. Which is more than the battery can output. This would be possible with brushless outrunner motors and Lipo batteries( RC plane equipment), but not possible with allowed parts.
Unread 09-01-2016, 19:41
Best Available Data
FRC #1778 (Chill Out!)
Re: Flying?
I've always thought it would be a fun off-season project to do a fixed wing FRC legal airplane. Based on the thrust folks got out of propellers in 2009 you could definitely make it work, but the takeoff performance to circle within an FRC regulation field would certainly be... challenging to say the least.
It reminds me of an exceptional Dave Lavery quote.
Originally Posted by dlavery
The rules also never explicitly say that I can't park a Boeing 747 right in the middle of the play field and use it as an obstacle for the other alliance. But after a little thought, something tells me that I probably should not do it.
Unread 09-01-2016, 19:58
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
Re: Flying?
Originally Posted by rtfgnow View Post
Read the blue box of G17.
G17 states that measurements are made with robot resting on the floor. Does not disallow flying or leaping.
G44 states that you cannot use the SHIELDS to cross a DEFENSE.
Leaping or flying over the DEFENSE in the space between the SHIELDS, does not violate either of these rules.I would love to see it done and suspect that flying is an almost impossible engineering challenge, but leaping...
R22 is similar to previous years and we have had all sorts of climbing and scaling operations that take the bumpers away form the floor. I would think that R22 is enforced like G17, with measurements made in a static configuration resting on the floor.
Unread 09-01-2016, 20:04
pilleya's Avatar
Elec+Mech
Re: Flying?
A fixed wing could probably work but, would require a big flight surface. Perhaps the control system with router, would not have sufficient range to comfortably fly the aircraft without risk of loss of communication.
Unread 09-01-2016, 20:06
FRC Warrior FRC Warrior is offline
FRC #4169
FRC Warrior is an unknown quantity at this point
Re: Flying?
Maybe G1?
Unread 09-01-2016, 20:09
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: Flying?
R22 BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained
between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
Leaping is still a-go.
Andy Bare
Team 1261
Unread 11-01-2016, 08:56
SPORK_Guy's Avatar
SPORK_Guy SPORK_Guy is offline
Team SPORK Captain
AKA: Jacob Ferrier
FRC #3196 (Team SPORK)
SPORK_Guy is an unknown quantity at this point
Re: Flying?
Originally Posted by GaryVoshol View Post
See the sub-section on "Shields" in part 2 of the manual - they're only 2 feet tall.
That doesn't necessarily mean the robot can't go over it, they just have to go between them. At least that's what we are rolling with.
Unread 11-01-2016, 09:26
apm4242 apm4242 is offline
FRC #4242
apm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud ofapm4242 has much to be proud of
Re: Flying?
Not totally on point but related - What about a tethered flying minibot to place a hook on the tower rungs?
Unread 11-01-2016, 09:31
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
Re: Flying?
Crossing: "Traverses the DEFENSE such that its BUMPERS go fully between the adjacent SHIELDS/GUARDRAIL"
So unless the drone IS the entire robot perimeter with bumpers (16 x 16 worth minimum)
So a drone without all the bumpers would not do anything as no damage or crossing would occur.
If that same drone can score boulders already in opponent courtyard then perhaps its viable (without bumpers)
That could be this years modular:
A main bot with BUMPERS and ability to deliver balls cross defenses and can handle most maybe even the low bar with ball.
A drone that separately fly's over field scoring opponent boulders somehow and can grab other boulders and deliver them to main bot to cross then when on opponent courtyard reacquires the boulders and scores the only defense they cannot cross over is low bar.
At the end it would have to either land on the main body or contact it somehow.
If a team pulls this off cool.
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
Unread 11-01-2016, 09:47
StanMan2000 StanMan2000 is offline
StanMan2000 is an unknown quantity at this point
Re: Flying?
If I remember right, your bumper has to be 1 inch off the ground. If you can make a flying robot with 38" propellers and a 13lb battery which hovers one inch off the ground with full sized bumpers, (that is clearly designed to play the game) I don't think FIRST will stop you.
Unread 11-01-2016, 10:01
asid61's Avatar
asid61 asid61 is offline
AKA: Anand Rajamani
FRC #0115 (MVRT)
Re: Flying?
Read farther up; bumpers don't stop you.
Unread 11-01-2016, 10:18
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Re: Flying?
1" off the ground is not the definition of the BUMPER ZONE this year - check the rulebook for the exact details (R22, also quoted by AndyBare a few posts above).
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 11-01-2016, 13:29
SPORK_Guy's Avatar
Team SPORK Captain
AKA: Jacob Ferrier
Re: Flying?
So I guess that if the robot's starting position has bumpers in the mandated volume then it should be fine....
Unread 11-01-2016, 13:47
Josho499#4613's Avatar
Josho499#4613 Josho499#4613 is offline
Student
Team Role: Student
Josho499#4613 is just really niceJosho499#4613 is just really niceJosho499#4613 is just really niceJosho499#4613 is just really nice
Smile Re: Flying?
Originally Posted by SPORK_Guy View Post
So, we are searching for a rule in the manual that specifically forbids creating a robot that has the ability to fly....my better judgement says that this is a bad idea, but I cannot find a rule against it. If you have found a rule please let me know, for it could change our entire design
Well I will certainly watching your regional
- Semi Finalist Curie Division 2015
- Regional Chairmans/Winner Australia 2016
- Finalist Western Canada 2016
