Re: Max number of high goals?
Section 3.3.2 has a pretty conclusive passage indicating that the STRENGTH of a TOWER can be negative. It can also go above eight.
In section 3.3.2 it states "Although the FEILD lights will only show a maximum STRENGTH equal to zero,there is no maximum or minimum STRENGTH for a TOWER."
So if you have really good shooting robots ... is there any technical foul that is actually worth taking if the tower is at -5 defense?
Plus they generally discourage intentional fouling. |
As far as we could tell, the 'score of diminishing returns' is 210 in elimination matches (or 216 if you can get the two "Reach Defense" auto points in addition to the 10pts for going through a defense in auto)... but, yes, you can just continually score high goals if your alliance is highly skilled. Additionally, it seems possible (just *highly* difficult) to score some of the balls on the midline in auto for a higher auto score, if you can grab the balls without crossing/interfering with the midline.
60 Auto - 30 points from crossing 3 defenses, 30 points for scoring 3 high goals (perhaps can get 6 more, if "reaching" and crossing defenses aren't mutually exclusive in auto) 35 Damaging-Defenses points (5 each, remaining 7 defense-crossings left after auto) 20 Breach points - 1 20pt bonus 25 Boulder points - 5 high goals in teleop 45 Scaling points - 3 robots scaled tower 25 Capture points - 1 25pt bonus for defeating the 'tower' with 8 balls and scaling/challenging it |
But since you cannot control more than 1 boulder at a time, you would need to cross over to the courtyard, shoot, go back, intake a midline ball, cross, and shoot again, all in 15 seconds.
Also, G13 would make it even more difficult. You would have to intake the midline boulder without touching the midline, which means that you would have to be able to intake a boulder from the side instead of from the top. This might be possible, but I'm certainly not going for it. Quote:
#8
I agree it won't be *easy*. But I won't be surprised at all to see it done. |
