Go to Post I thanked the tradesmen on our team the same way i do ever year with a handshake and a "thanks for helping us guys", - Mike Schroeder [more]
Unread 09-01-2016, 20:13
Vyrotek's Avatar
Vyrotek Vyrotek is offline
AKA: Jason
FRC #0498 (Cobra Commanders)
Vyrotek is an unknown quantity at this point
Does scaling/challenging require a weakened tower?
A ROBOT has SCALED the TOWER if, at the conclusion of the MATCH, the ROBOT:
A. is in contact with a unique RUNG, and
B. has all of its BUMPERS fully above the height of the low GOALS.
A TOWER is CAPTURED if, at the conclusion of the MATCH:
A. the TOWER is WEAKENED, and
B. the TOWER is surrounded such that each of the three (3) opponent ROBOTS has
SCALED or CHALLENGED a unique face of the TOWER
The rules don't seem to indicate that you must weaken the tower in order to get points for scaling or challenging it. Is this the case?
Unread 09-01-2016, 20:21
MichaelaLeung MichaelaLeung is offline
FRC #4915
MichaelaLeung is an unknown quantity at this point
Re: Does scaling/challenging require a weakened tower?
No, scaling and challenging can be done on an unweakened tower and the points still scored but you cannot capture an unweakened tower.
Unread 09-01-2016, 20:29
lblight98 lblight98 is offline
FRC Rookie 2015
FRC #5150 (Hyrbid Hornets)
Rookie Year: 2016
lblight98 is an unknown quantity at this point
As far as I can tell, capturing the tower takes all 3 bots around a tower that has no life left, but challenging and scaling seem to not require 0 life in the tower. WEAKENED is defined as "the state of a TOWER if its STRENGTH is at or below zero (0)", so the tower apparently should have to be at 0 (or less??) health to be a capture
Happy Building!
