Go to Post But that is not all-FIRST is about teaching mentors what kids are like all over again. It's about closing the generation gap, creating bonds, life time friends, and skills that will last everyone involved a lifetime. - Team0 [more]
Unread 09-01-2016, 21:05
NAP17 NAP17 is offline
FRC #4361
NAP17 is an unknown quantity at this point
Question Difference between Scoring and Passing
I am a member of Roxbotix Team 4361. I perused the manual for First Stronghold. I "ctrl-f'ed" for passing and I could not find anything. I have been talking to one of my team members and a question arose. Can you pass from your side to the opponents side of the field without getting a foul? If you can this would save a tremendous amount of time.
Thanks
Unread 09-01-2016, 21:06
medofbr medofbr is offline
FRC #5404
medofbr is an unknown quantity at this point
Re: Difference between Scoring and Passing
No
Unread 09-01-2016, 21:10
FRC #4361
Question Re: Difference between Scoring and Passing
Where does it say this?
ATannahill ATannahill is offline
AKA: Alex Tannahill
Thanks
Yes, by crossing their defenses.
When you say "you pass", I assumed the robot was traversing the field.
Dhill098 Dhill098 is offline
AKA: Damian
FRC #2383 (Ninjineers)
Team Role: Driver
Dhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to behold
G40 - A ROBOT may not cause a BOULDER to move from the NEUTRAL ZONE into the opponent’s
COURTYARD unless:
A. the ROBOT contacts the BOULDER within OUTER WORKS, and
B. the ROBOT completes its CROSSING (i.e. doesn’t completely back out of the OUTER
WORKS into the NEUTRAL ZONE)
Violation: TECH FOUL per BOULDER
You need to have contact with the ball as you go through the Outer Works
Unread 09-01-2016, 21:11
bvisness's Avatar
bvisness bvisness is offline
Programming Mentor, Former Driver
bvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of lightbvisness is a glorious beacon of light
You really owe it to yourself (and to every team you will ever play with) to read the manual in full...
If you did, you would have encountered rule G40, which governs moving Boulders down the field. To encourage you to actually read the manual, I won't state the rule here
2014 IRI Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship Winners (Thanks 2052, 4778)
2014 Archimedes Quaterfinalists (Thanks 399, 2056, 2834)
2013 Minnesota State Championship Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
Unread 09-01-2016, 21:14
FRC #4361
Thank you so much and thank for providing the source. Hope you have a great season!
Unread 09-01-2016, 21:15
alopex_rex's Avatar
alopex_rex alopex_rex is offline
Rainbow Professionalism Dash
AKA: Scott Morton
FRC #0830 (The RatPack)
alopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond reputealopex_rex has a reputation beyond repute
You're going to have to explain by what you mean by "passing" to get a definite answer. If you mean launching the ball from your courtyard to your opponent's courtyard, this is forbidden by G39. I would also have a look at G40, which specifies the legal ways to take a boulder from the neutral zone to your opponent's courtyard.
Ratpack programming lead 2013 - 2015
ἔκλαγξαν δ᾽ ἄρ᾽ ὀϊστοὶ ἐπ᾽ ὤμων χωομένοιο / αὐτοῦ κινηθέντος: ὃ δ᾽ ἤϊε νυκτὶ ἐοικώς. (Ancient Greek nerds unite!)
