Go to Post I heartily applaud FIRST for finally reacting proactively to this ongoing problem. - Ether [more]
Unread 09-01-2016, 21:09
Dorgnarg Dorgnarg is offline
FRC #3187 (Titans)
Dorgnarg is an unknown quantity at this point
Defense Selection
I'm just a little confused on the wording of the rules regarding defense selection. In 5.5.10, it says:
During the Practice MATCHES, ALLIANCES may select any four (4) DEFENSES from the four (4) groups.
For example, each of the two (2) DEFENSES from groups A and B. Also, OUTER WORKS DEFENSE
positions 2 through 5 are selected by the opposing ALLIANCE, i.e. the Red ALLIANCE selects the Blue
ALLIANCE DEFENSES. This provides each ALLIANCE with a predictable set of DEFENSES on which to
practice.
And then in 5.5.10.2, where it specifies teams choosing choosing defenses, it doesn't specify which teams choose the defenses. And the wording in the example is a little weird because it says
The DEFENSE selection process outlined for the Qualification MATCHES will also be employed during Practice MATCHES.
which seems to imply that the choosing process is the same?
My assumption is that the team chooses their own defenses (ie. Blue alliance chooses the defenses that red alliance will have to beat), but does it say that or is that just supposed to be implied? (It's entirely possible that it does and I'm not seeing it, but I didn't remember reading anywhere else specifically WHICH alliance chooses which defenses)
Unread 09-01-2016, 21:18
Dhill098 Dhill098 is offline
AKA: Damian
FRC #2383 (Ninjineers)
Team Role: Driver
Dhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to beholdDhill098 is a splendid one to behold
Re: Defense Selection
This is a good question for Q&A. It makes sense that you pick the defenses that your opponent will have to go through before firing boulders at your castle in qualifying rounds. But practice rounds should be used to practice navigating the defenses.
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
The selection of defenses is explained more thoroughly in 5.5.10
Unread 09-01-2016, 21:19
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
I refer you to section 5.5.10.2. The answer to your question should be in there.
Unread 09-01-2016, 21:22
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
5.5.10:
the Red ALLIANCE selects the Blue ALLIANCE DEFENSES. This provides each ALLIANCE with a predictable set of DEFENSES on which to practice.
That means your alliance will end up picking which defenses it will have to cross.
Unread 09-01-2016, 21:25
Brad Hanel's Avatar
Brad Hanel Brad Hanel is offline
Sharpie Thief
AKA: B
Brad Hanel is on a distinguished road
"The DEFENSE selection process outlined for the Qualification MATCHES will also be employed during Practice MATCHES."
I believe this is only talking about the process in which teams pick defenses two matches ahead of time and the like, not specifically whose defenses they pick, but I could be wrong.
Master of Tactics
AKA: Scott Hasek
FRC #1987
Yes NShep98, but that's only for practice matches.
Unread 09-01-2016, 21:32
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Yeah this just means they will employ the use of the Defensive Coordinator in all matches. During actual Qual and Elim matches you have to pick the defenses your opponent has to cross.
Unread 09-01-2016, 21:39
NShep98's Avatar
Rookie Year: 2015
In that case, the only part I see that pertains to this is in the beginning of parts 2,3, and 5
FIRST STRONGHOLD is a medieval tower defender game in which two (2) ALLIANCES of three (3) Teams
each select DEFENSES to fortify their OUTER WORKS before competing simultaneously to score points
while BREACHING the opponent’s OUTER WORKS and CAPTURING the opponent’s TOWER.
Where you select your own defenses.
Unread 09-01-2016, 21:41
cgmv123's Avatar
cgmv123 cgmv123 is online now
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
"own defenses" refers to the DEFENSES of your own CASTLE, which the opponent is trying to BREACH/CAPTURE.
Unread 09-01-2016, 21:43
NShep98's Avatar
Rookie Year: 2015
That is what I meant to say, yes.
Unread 09-01-2016, 21:46
Zach101's Avatar
Zach101 Zach101 is offline
Oh captain, my captain
AKA: Zach Hagen
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
Zach101 has a spectacular aura aboutZach101 has a spectacular aura aboutZach101 has a spectacular aura about
This thread is pretty much answered but if you're still confused head to this thread. Answers the same question. Who Chooses?
2015 MSHSL State Championship Winners with 3130 and 4215
2015 Hopper Division Winners & Einstein Finalists with 987, 2826, and 4265
2015 Northern Lights Chairman's Award Winners
Finalists at the 2015 Central Illinois Regional with 4143 and 4212
Finalists at the 2015 Northern Lights Regional with 5172 and 4786
2015 Prior Lake Mini Regional Winners with 2169 and 4859
2014:Strategy 2015:Electrical 2016:Strategy Captain
<Hopper Division Announcer> 'When I said Admiral, you say Hopper... Admiral! Ackbar!
Unread 10-01-2016, 01:11
FRC #3187 (Titans)
Awesome, thanks everyone!
