Go to Post The few people who don't ever make mistakes are the same people who simply don't do anything. What people do after they make a mistake tells others what they are made of. - Andy Baker [more]
View Poll Results: Could this be helpful?
Yes! This will make everyone's lives easier 16 57.14%
No, this just will make everything more complicated 12 42.86%
Voters: 28. You may not vote on this poll
Unread 09-01-2016, 20:41
jamison511 jamison511 is offline
FRC #1757
jamison511 is an unknown quantity at this point
Communicating with the spy
With electronic communication out of the question, would it make sense for teams to come together and create a standard set of hand/flag signals. What do you think about the feasibility of a standard system?
Unread 09-01-2016, 20:59
timtim17's Avatar
timtim17 timtim17 is offline
Programmer
AKA: Austin
FRC #1294 (Top Gun Robotics)
timtim17 has a spectacular aura abouttimtim17 has a spectacular aura abouttimtim17 has a spectacular aura about
Re: Communicating with the spy
Our team seemed to agree at our kickoff session today - we were thinking some sort of ASL or standardized gestures (depending on the extent on what the spy is allowed to do) that all teams could understand.
Unread 09-01-2016, 21:00
Calvin1119 Calvin1119 is offline
AKA: Brock W
FRC #1306 (BadgerBots)
Calvin1119 is an unknown quantity at this point
I was having the same idea. There's only one spy per alliance, so you'd either have to learn a new system each match or have it be standardized. All the spy is doing is showing where the robots are, so there's no disadvantage to having it be standard throughout FIRST.
Unread 09-01-2016, 21:10
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
First thought our team had. It would be a good idea to have an "unoffical" hand signal set so most teams would have a basic understanding and not have 30-70 (saying every team had a slightly different one at some big regional)
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2016, 21:12
Eric Scheuing's Avatar
Eric Scheuing Eric Scheuing is offline
FRC #0999 (MechaRAMS)
Eric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud ofEric Scheuing has much to be proud of
Doesn't say anything about cup-and-string communication. Technical diagram included.
2005-2007: Bobcat Robotics 177
2015-20XX: MechaRAMS 999
Unread 09-01-2016, 21:14
AKA: Brock W
Does a string count as a wire?
Unread 09-01-2016, 21:29
Mike9966's Avatar
Mike9966 Mike9966 is offline
Mentor Mike
FRC #2846 (Fire Bears)
Mike9966 is an unknown quantity at this point
How about a flashlight, incandescent of course so it's not electronic......
Do the best you can! Always
Go FireBears
2009 10000 Lakes Finalists, thanks 2825 & 2177
2010 10000 Lakes quarter finalists
2011 Duluth and 10000 Lakes
2012 Superior, and 10K Lakes, Qt finals, MRI
2013 Northern lights, 10K Lakes-Semi finalists, MRI, River Rendezvous, Minne Mini
2014 Northern Lights, 10K Lakes
Unread 09-01-2016, 21:36
TheGabe's Avatar
TheGabe TheGabe is offline
FRC #1259 (Paradigm Shift)
Team Role: CAD
TheGabe is an unknown quantity at this point
The spy's role is to tell the drivers what defenses in the outer works are being damaged and which ones are fully destroyed (2 crossings). There are lights on the ramps to indicate this, but lights only face the side of that alliance. So the lights face the drive walls not the neutral zone.
Unread 09-01-2016, 21:42
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
They also are useful for helping robots line up for firing at the towers, it that robot has a firing spot that can be identified by landmarks
You sure? Took this from the reveal video, sorry for the blurriness.
Unread 09-01-2016, 21:43
ATannahill ATannahill is offline
AKA: Alex Tannahill
Where did you get the idea that the lights are only on one side?
Unread 10-01-2016, 09:33
TheGabe's Avatar
Team Role: CAD
Sorry, a bunch of our mentors thought that's how it was when reading through the manual. It seems as though you guys are right, there are lights on both sides. Still though, it might be tricky for the drivers to see these lights with defenses in the way so the spy can still help out with that in addition to guiding robots.
Unread 10-01-2016, 09:57
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I was thinking something along the lines of this: https://www.youtube.com/watch?v=ZaOiaC0I8pY
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-01-2016, 11:08
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
There will also be the scoreboard showing health, and probably they will still have an info screen for the coaches, but that is still unclear.
