Go to Post Dang. There goes the hint that was supposed to go out next week. Gotta start over now.. - dlavery [more]
Unread 09-01-2016, 18:22
Team 3181 Team 3181 is offline
FRC #3181
Team 3181 is an unknown quantity at this point
Max number of high goals?
So we're trying to calculate the max score but if you still get points for high goals after the defense is down there is no max score.
We were reading the rules and they don't say you can't keep shooting high goals after the initial eight to lower its defense, so we are pretty sure this still counts for points, but does anybody know for sure?
Thanks.
Unread 09-01-2016, 18:30
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Re: Max number of high goals?
The way I read it is that you can continue to score boulders in either the high or low goals but you can't give the tower negative damage. So lets say you shoot 10 boulders into the castle, this means the towers defenses are at 0 not -2. But if you get a technical foul (even if you've scored 10 boulders) then the towers defenses go back to 1.
Unread 09-01-2016, 18:31
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Thanks.
You can continue to score in the high goal after the Tower is weakened.
Unread 09-01-2016, 18:35
ATannahill ATannahill is offline
AKA: Alex Tannahill
Look at page 31 and tell me why they would put "or below" on the page if that was the case.
Unread 09-01-2016, 18:41
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
Look at page 31 and tell me why they would put "or below" on the page if that was the case.[/quote]
Would be helpful if you said which section
Unread 09-01-2016, 18:48
AKA: Alex Tannahill
Well, it only appears once on page 31, but I meant in 3.1.4. That is the section that governs what you were referring to.
Unread 09-01-2016, 19:03
Jay Burnett Jay Burnett is offline
FRC #5332 (Toaster Tech)
Jay Burnett is an unknown quantity at this point
Also see the Glossary on the last page when it defines "Weakened"
Weakened: "the state of a TOWER if its STRENGTH is at or below zero (0)"
Unread 09-01-2016, 19:05
northstardon northstardon is offline
Robots are just like rocks, right?
AKA: Don Elsenheimer
FRC #2220 (Blue Twilight)
northstardon is just really nicenorthstardon is just really nicenorthstardon is just really nicenorthstardon is just really nicenorthstardon is just really nice
In addition to the "is at or below zero" language supporting the use of negative numbers, there's the simple statement in the previous sentence that a scored boulder decreases tower strength by 1 (i.e. that statement is not qualified by a phrase like "unless the tower is weakened.")
And since technical fouls add 1 to the tower strength, it wouldn't seem like a bad idea to get the strength down to -1 or -2, just in case a red flag gets waved towards the end of the match.
Unread 09-01-2016, 19:19
MasterEric's Avatar
MasterEric MasterEric is offline
Bacon. 'nuff said.
AKA: Eric Myllyoja (E2)
FRC #2137 (Oxford Robocats)
MasterEric is an unknown quantity at this point
Would be helpful if you said which section[/quote]
The relevant quote from page 31 of the Game Manual, Section 3.1.4 The TOWER
A TOWER is WEAKENED if the TOWER’S STRENGTH is at or
below zero (0).
Unread 09-01-2016, 20:23
Jake177's Avatar
Jake177 Jake177 is offline
AKA: JT, Jake Troiano
FRC #0177 (Bobcat Robotics)
Jake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to beholdJake177 is a splendid one to behold
Section 3.3.2 has a pretty conclusive passage indicating that the STRENGTH of a TOWER can be negative. It can also go above eight.
Although the FIELD lights will only show a maximum STRENGTH equal to the starting STRENGTH and a minimum STRENGTH equal to zero, there is no maximum or minimum STRENGTH for a TOWER.
Once a Bobcat, always a Bobcat
2001-2004: Student
(I'm told the team had a couple good years in between here)
2012 - Present: Mentor
Unread 09-01-2016, 21:34
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
In section 3.3.2 it states "Although the FEILD lights will only show a maximum STRENGTH equal to zero,there is no maximum or minimum STRENGTH for a TOWER."
Unread 09-01-2016, 21:40
dmorewood's Avatar
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
So if you have really good shooting robots ... is there any technical foul that is actually worth taking if the tower is at -5 defense?
Unread 09-01-2016, 21:44
Brad Hanel's Avatar
Brad Hanel Brad Hanel is offline
Sharpie Thief
AKA: B
Brad Hanel is on a distinguished road
The other team still gets points, so it would just be like a normal foul with points for the other team.
Plus they generally discourage intentional fouling.
Unread 09-01-2016, 22:26
Nathan Streeter's Avatar
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
As far as we could tell, the 'score of diminishing returns' is 210 in elimination matches (or 216 if you can get the two "Reach Defense" auto points in addition to the 10pts for going through a defense in auto)... but, yes, you can just continually score high goals if your alliance is highly skilled. Additionally, it seems possible (just *highly* difficult) to score some of the balls on the midline in auto for a higher auto score, if you can grab the balls without crossing/interfering with the midline.
60 Auto - 30 points from crossing 3 defenses, 30 points for scoring 3 high goals (perhaps can get 6 more, if "reaching" and crossing defenses aren't mutually exclusive in auto)
35 Damaging-Defenses points (5 each, remaining 7 defense-crossings left after auto)
20 Breach points - 1 20pt bonus
25 Boulder points - 5 high goals in teleop
45 Scaling points - 3 robots scaled tower
25 Capture points - 1 25pt bonus for defeating the 'tower' with 8 balls and scaling/challenging it
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 10-01-2016, 00:10
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Sorry, but no. Read the paragraph above the blue box in 3.1.3; you can only score 1 DEFENCE points method for CROSSING one DEFENSE, one time, in auto. That includes REACHING. 3.1.3 doesn't say anything about multiple ball scores in auto.
Mentor http://www.teamtitanium.org/
