Go to Post Achieving a goal by merely finishing, or reaching mediocrity is not acceptable; Excellence is the only satisfactory result. - AdamHeard [more]
Unread 09-01-2016, 22:01
JohnSchneider's Avatar
JohnSchneider JohnSchneider is offline
JohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond reputeJohnSchneider has a reputation beyond repute
Re: Breacher Bot
Originally Posted by Boltman View Post
G20 ROBOTS may only enter or exit their opponent’s SECRET PASSAGE from/to the opponent’s COURTYARD. A ROBOT is considered to be within the SECRET PASSAGE once the only carpet the ROBOT is in contact with is the carpet inside the SECRET PASSAGE.
Help me visualize what the robot can do under this rule. Does that mean the robot can only use the Secret Passage on the side containing the courtyard? If you go beyond that past ramp where the defenses are its a foul?
So that only allows inadvertent use of the SP?
You can enter your opponents secret passage only through their courtyard. So the long side. There are no rules prohibiting you from going to the end of the secret passage, past the defenses, but you may not enter to exit their secret passage from there. Only through their courtyard.
In order to move between the neutral zone and your opponents courtyard you must ALWAYS go through a defense.
