Go to Post Every year I develop new connections and greater friendships with FIRSTers - and every year I am surprised to find just how many amazing people there are here. - MysterE [more]
Unread 09-01-2016, 22:09
New Lightning's Avatar
New Lightning New Lightning is offline
Master of Tactics
AKA: Scott Hasek
FRC #1987
New Lightning has a spectacular aura aboutNew Lightning has a spectacular aura about
Clarification on Rule G43
G43 ROBOTS on the same half of the FIELD as their ALLIANCE TOWER may not interfere with opponent ROBOTS attempting to traverse OUTER WORKS (regardless of direction). A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS. Violation: FOUL. For every five (5) seconds in which the situation is not corrected, FOUL
So does this mean that I can't patrol back in forth in front of my teams outer works to prevent the other alliances robots from reaching the outer works in the first place?
Unread 09-01-2016, 22:15
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond reputeMikLast has a reputation beyond repute
Re: Clarification on Rule G43
You can patrol, but it will count as pinning and you will get a foul.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Master of Tactics
AKA: Scott Hasek
FRC #1987
Could you elaborate on how it would be pinning so long as your were just parking yourself in their way?
Unread 09-01-2016, 22:18
Boltman Boltman is offline
FRC #5137 (Iron Kodiaks)
Boltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud ofBoltman has much to be proud of
That would likely be interfering with their crossing the defense on your side , pretty sure a foul unless past the midline on their side which would be more useless
Iron Kodiaks Team #5137 San Marcos, CA
2016 Semi-Finalist | Central Valley Alliance Captain #2
2016 Semi-Finalist | San Diego 2nd bot alliance #8
2015 Semi-Finalist | Ventura 3rd bot alliance #3
2015 Quarter-Finalist| San Diego 2nd bot alliance #5
2014 Rookie All-Star | #21 San Diego | Galileo Division #91
MikLast's Avatar
CAO/Drive Coach
inhibits forward movement, which seems to be pinning as some dont allow you to go back easily.
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud ofNShep98 has much to be proud of
I don't believe that would count as a pin because you are not restricting movement in all directions. It seems like there is no rule preventing you from blocking a defense as long as they are not already in the middle of going across it. Patrolling the back end of the defense would be a violation because you are now preventing the opposing robot from completely crossing.
Unread 09-01-2016, 22:19
Master of Tactics
AKA: Scott Hasek
FRC #1987
I was referring only to the front end of the defenses.
Unread 09-01-2016, 22:22
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
i think that as long as they haven't touched the outer works yet, your good. But if the have come into contact with the works, you cant touch then.
Unread 09-01-2016, 22:23
Master of Tactics
AKA: Scott Hasek
FRC #1987
Okay that makes since.
Unread 09-01-2016, 22:27
the programmer's Avatar
the programmer the programmer is offline
AKA: Erik Orlowski
FRC #2830 (Riverside Robotigers)
the programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud ofthe programmer has much to be proud of
My interpretation is that if their bumpers are not crossing the plane of the outer works, you can do as much patrolling as you want. However, as soon as their bumpers cross the plane of these outer works, if a referee thinks you are "interfering" with a team crossing the outer works, it's a foul.
2006-2008: FLL Student
2009-2014: C.O.R.E. 2062
2010-?: FLL Referee
2015-?: Riverside Robotigers 2830
Unread 10-01-2016, 01:07
This interpretation. And bear in mind that it's BOTH ways, in or out.
Unread 10-01-2016, 06:21
Hathawulf's Avatar
Hathawulf Hathawulf is offline
FRC #3574
Hathawulf is an unknown quantity at this point
Check rule G25, blue box, last line.
Unread 10-01-2016, 07:12
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Pinning is a different violation. No need to reference that rule.
Unread 10-01-2016, 16:06
Tymethy's Avatar
Tymethy Tymethy is offline
Scouting Captain
AKA: Tymothy
FRC #3824
Tymethy is an unknown quantity at this point
You may patrol as long as you do not come into contact with them when they are counted within the outerworks. The neutral zone is free game.
