Go to Post We might not be as good as 217, or the other traditional "powerhouse" teams... but we are better because of them. Jason - dtengineering [more]
Unread 09-01-2016, 21:29
engunneer's Avatar
Alumni turned Mentor
AKA: Branden Gunn
FRC #4761
Re: Universal Spy Hand Signals
Originally Posted by Chito View Post
im not liking this whole hand signal idea
you don't have to, but if there becomes a standard set of signals, you may get some advantage from using them.
What's not to like?
Unread 09-01-2016, 21:31
JoshWilson's Avatar
JoshWilson JoshWilson is offline
FRC #0230 (Gaelhawks)
JoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to allJoshWilson is a name known to all
A universal code is great, because it allows any alliance robot on your side to know what's going on. It won't help opponents, because they can already see what's going on, so that won't hurt much.
Here's the list of things that should be discernible:
•which way to move: a MUST. Without this, the spy is worthless.
•when your good and can fire/perform function: Also a must. I also suggest for some tasks, teams try to line up with guide lines so that spies can tell it when it's good for firing.
•What robot your talking to: of there are two robotics in the opponent's courtyard, then you need to be able to say which one your talking too. Otherwise, confusion will occur.
Unread 09-01-2016, 21:39
JacksonNguyen JacksonNguyen is offline
FRC #1738
JacksonNguyen is an unknown quantity at this point
@Chito
Unread 09-01-2016, 21:40
Chito Chito is offline
FRC #5000
Chito has a spectacular aura aboutChito has a spectacular aura about
i like that jackson guy
Unread 09-01-2016, 21:42
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to beholdMikLast is a splendid one to behold
Originally Posted by JacksonNguyen View Post
Post productive things, not whatever was before the image and the image itself, this does nothing but clutters the thread with useless replies.
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 09-01-2016, 21:43
The Ginger's Avatar
The Ginger The Ginger is offline
#GingerPower
FRC #5464 (BluejacketRobotics)
Team Role: Driver
Rookie Year: 2015
The Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud ofThe Ginger has much to be proud of
The think is, it doesn't matter if your opponent knows your code, everything that the spy is telling you is rate in front of their faces. they arn't learning anything from your spy that they don't already know/see.
Unread 09-01-2016, 21:44
FRC #5000
woah u dont talk to muh man jackson like that. calm down man
Unread 09-01-2016, 21:47
MikLast's Avatar
CAO/Drive Coach
The idea of hand signals is to relay info that the drive team may not be able to see (for example making sure the bot is lined up properly to shoot)
Unread 09-01-2016, 21:48
FRC #1738
https://www.google.com/search?q=fusi...l7kMP_jrNYM%3A
Unread 09-01-2016, 21:51
FRC #5000
U AR RITE. HADN SNGLS R D BST.
Unread 09-01-2016, 22:21
katahar's Avatar
katahar katahar is offline
AKA: Rishi Basdeo
FRC #2797 (Knight & Nerdy)
katahar is an unknown quantity at this point
Is there anything in the rules against the spy holding up a big sign with an arrow on it? He/she would just have to rotate it in the right direction, and there would be almost no miscommunication.
Unread 09-01-2016, 22:26
NShep98's Avatar
NShep98 NShep98 is offline
AKA: Nathan Shepherd
FRC #2079 (4H ALARM Robotics)
Rookie Year: 2015
NShep98 is on a distinguished road
My idea for this would be to have three colored cards. Red = team 1, white = team 2, blue = team 3. With one hand, hold the corresponding card, with the other some sort of signal.
Teams are going to have to do a lot of communicating with partners on what signals should be used.
Unread 09-01-2016, 22:30
Collin Stiers's Avatar
Collin Stiers Collin Stiers is offline
FRC #1719 (Umbrella Corporation)
Team Role: Driver
Collin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really niceCollin Stiers is just really nice
what about the old semaphore flag signals armies used to use? most commonly the flags formed specific letters, but I know armies in the civil war used them to direct the movement of specific divisions.
Unread 09-01-2016, 22:31
MattOz MattOz is offline
FRC #5416 (TaRDIS)
Rookie Year: 2015
MattOz is an unknown quantity at this point
Is the hand signals really that important since almost every robot has a camera or cameras to give visual aid to the drive team?
Unread 09-01-2016, 22:33
NShep98's Avatar
Rookie Year: 2015
While that is a possibility, A) You can only see so much through a camera pointed in one direction, and B) Some teams may not be capable of getting a camera working.
