Re: Stealing your opponents boulders
However, if you are blocking the secret passage so that no matter what they do they end up with over 6 and cant get rid of any boulders because they are automatically redirected into their alliance station, you are putting them into an endless loop that no matter what they do, the end up with over 6 boulders and cant get rid of them, due to a strategy that essentially forces them to take penalties because they cant get rid of a ball. That's where it gets a little grey. Do you get a G11 for using a strategy that involves essentially forcing them to have over 6 boulders? Maybe. I'm unsure but its a possibility and should be asked don the Q&A Last edited by KosmicKhaos : 09-01-2016 at 23:48. |
I'll remind you of
G11 Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FIRST Robotics Competition and not allowed. Rule violations forced in this manner will not result in an assignment of a penalty to the targeted ALLIANCE. Violation: FOUL. If egregious or repeated, YELLOW CARD That pretty much counts out blocking the feeding station. |
As a side note the opponents just can't keep more than 6 boulders inside their castle. It says nothing about feeding them to their own robots; that's just preferred. |
As long as you are not touching the carpet in the SP you don't run the risk of violating G21 or G39. Only issue is with how you block the EMBRASURE. If they can get BOULDERS onto the field touching your robot you could end up in violation, via "trapping", of G38. I would like to see G38 clarified before building a robot around this strategy. |
It's 100% your fault they are feeding balls to you
that's kinda the point right? That being said. All they need to do it throw a ball out of both EMBRASURE at once and you would get a foul for controlling multiple boulders! Last edited by T3_1565 : 10-01-2016 at 08:28. Reason: used correct terms |
#7
G38 needs clarification. If a ball ends up between you and the EMBRASURE due to your position relative to the EMBRASURE, is this "trapping" or "herding". You are not holding the BOULDER against a FIELD ELEMENT. They specifically state that "deflecting" is not "control". |
