Go to Post If FIRST is going to succeed in its goals, then we need to help it. - jcatt [more]
Unread 09-01-2016, 23:57
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
Question How to calculate camera position from retroreflectors
Knowing the size and positions of these reflectors and assuming that the center of the field is (0,0) (or maybe there is one more zero for the camera's z?), how (mathematically) can I take pictures from a camera and calculate the camera's position on the field? Thanks in advance!
Unread 10-01-2016, 00:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: How to calculate camera position from retroreflectors
The height of the camera will be constant on most robots.
Trigonometry. You have a known length and an angle from the image.
Unread 10-01-2016, 00:04
Could you give me a link explaining how I'd do it? I don't have a super strong math background.
Unread 10-01-2016, 00:07
cgmv123's Avatar
AKA: Max Vrany
length of target/tangent(angle of target in image) = distance to target
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
This thread from 2012 might be a good place to start, specifically this post
Unread 10-01-2016, 00:09
But that only gives me distance, how do i determine where I lie on that circle?
Unread 10-01-2016, 00:16
Aur0r4's Avatar
Aur0r4 Aur0r4 is offline
Engineering Mentor
AKA: Jim Browne
None #1058 (PVC Pirates)
Aur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant futureAur0r4 has a brilliant future
Send a message via AIM to Aur0r4
We took a stab at this exact same situation a few different years, and its actually significantly harder than it sounds. Aside from the actual mathematics of it, the cameras we have access to do not produced a "flat" image. It has spherical distortion that isn't really obvious until you try doing math on different parts of the image. Even high end cameras used for actual aerial survey have this problem....we see it in "orthophotos" that have been corrected to give a reasonably "flat" picture that you can make measurements on. The jagged corrections made to straight line objects like roads gets more and more obvious the farther you get from the center of the frame. Also, parallax and other problems.
We can certainly learn things from the camera image, don't get me wrong.
Definitely rooting you on for trying to figure this out, and I'm definitely not saying its not objectively possible. Its just really, really hard with the equipment and processing power we have.
Jim Browne, EIT
Team 1058 - PVC Pirates
Unread 10-01-2016, 00:19
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
How does the camera handle multiple targets (If I'm at an angle where two high goals can be seen by the camera at once)?
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
OK. Is there a way to accurately track our robot's position on the field? We tried using a 6DOF IMU from sparkfun last year and the due to the compressor's vibrations, the readings were so inaccurate they were unusable.
http://wpilib.screenstepslive.com/s/...ng-the-targets
Unread 10-01-2016, 00:22
Aur0r4's Avatar
Engineering Mentor
AKA: Jim Browne
That's another issue we ran into....the camera is generally not stable enough for detailed calculations...of course, maybe that was just the mecanum wheels...
That's a very good question. The answer of a how to create a true "FRC GPS" is probably going to be a combination of techniques that might include camera data, inertial guidance data, floor features, range-finders, etc that all can be used to develop a "reasonable" position on the field. But someone's software team is going to have their work cut out for them, that's for sure.
Jim Browne, EIT
Unread 10-01-2016, 00:24
We should suggest for next years game that there be a few devices on the outside of the field that your robot can ping to calculate it's position.
Unread 10-01-2016, 00:32
Aur0r4's Avatar
Engineering Mentor
AKA: Jim Browne
Well, that's certainly where things get interesting.... As you said earlier, you know where in a circle you are right now....all you need is one more circle to narrow it down to only two possible locations. I'd be curious to see what kinds of results someone could get with two cameras...one looking at each tower (assuming you can see them). Dunno if the control system infrastructure could support that, but that would get you going in the right direction.
Jim Browne, EIT
