Go to Post I've learned never to say never when it comes to FIRST teams. - Karthik [more]
Unread 10-01-2016, 00:57
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
Pneumatic Wheel Swerve
On our team's list of goals to achieve, we obviously wanted to be able to cross the defenses, but also align properly in the limited space in the neutral zone. We really want to do pneumatic wheels to get over the rough terrain, but swerve to navigate easier and lock our wheels in for shots.
So how does a pneumatic wheel swerve sound? I put together a little something in CAD to illustrate the concept. I forgot to disable the transparency on the sprockets in the first image, but the second one shows it.
"Why is the sprocket so big?" you ask. One of our mentors considered traditional modules to experience significant loads when on just a few wheels and unable to hold up. I attempted to mitigate this problem by using a slotted delrin ring strapped onto the bottom the tube. This helps by having a grove to keep the module in place as well as distributing load on around 15 square inches of slick plastic.
So what do you think? I tried to keep the complexity down so only 4 gears per module and versaplanteries with encoders to turn the modules. Would this be too complicated or just outright unable to work?
Also is there a better way of turning the modules without adding another 4 motor controllers?
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 10-01-2016, 01:23
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: Pneumatic Wheel Swerve
If you haven't done a swerve before I would be hesitant on embarking on that challenge during the build season. Based on our initial testing, powering through obstacles will be relatively strenuous on your drive train so take that into account.
461 Westside Boiler Invasion
45 Technokats
Unread 10-01-2016, 10:10
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
I helped with a pneumatic wheel swerve in college. We had a much higher weight limit and greater freedom in the choice of parts which helped a ton. Definitely possible, in general. However, the whole mechanism was still somewhat fragile - I'd be super worried this year about a module getting wedged in one of the defenses and burning out a motor. I wouldn't do it, but that's just me.
Edit: Here's some pictures of what we did: http://imgur.com/a/JkeBG
Unread 10-01-2016, 10:13
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
I actually ended up building a pneumatic swerve earlier in the fall. It worked but was heavy and really big. The wheels I ended up using were 8" diameter wheels from McMaster-Carr
Unread 10-01-2016, 12:17
jkelleyrtp's Avatar
AKA: Jon Kelley
So we might not be doing swerve, but for my own edification I'd like to know the key areas of stress in a swerve module. I assume there will be a cantilever force through the central axle as well as loads into the chassis and into the retaining bearings.
There will also be a force acting down and away from the axle protruding into the module, creating a pivot point.
I plan to isolate vertical shaft displacement with retaining clips and maybe even shaft collars, but I really don't know the numerical loads it will face. What have I missed? How in Solidworks can I get a stress analysis based off of the loads?
Mechanical, CAD
