Go to Post Picking up tetra's is going to be as easy as picking up a person of the opposite sex. While a select few will master it; others will be bumbling maroons.. - Elgin Clock [more]
Unread 01-10-2016, 01:02 AM
ollien ollien is offline
FRC #5202
ollien has a spectacular aura aboutollien has a spectacular aura aboutollien has a spectacular aura about
R4 clarification
When strategizing with my team, the question came up whether or not we could have a piston, for example, that would extend in front of the bumper. I've crudely drawn a together a couple of diagrams to demonstrate what I mean.
Before the match started, the robot would start like this:
and at some point during the match, to pick up a boulder, for example, the pistons would extend and form something like this:
When checking the rules, I came across R4 which states
In the STARTING CONFIGURATION (the physical configuration in which a ROBOT starts a MATCH), no part of the ROBOT shall extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
However, this only states that the robot can't start with something extruding past the bumper. Would I be able to extend something below the bumper like that?
Thanks so much!
Unread 01-10-2016, 01:06 AM
Re: R4 clarification
Keep reading. BACKWARDS in this case, to R3B. You're just fine, provided that it's retracted to start and <=15" past the Frame Perimeter when deployed.
Unread 01-10-2016, 01:10 AM
nickbrickmaster's Avatar
nickbrickmaster nickbrickmaster is offline
Captain
AKA: Nick Schatz
FRC #3184 (Blaze Robotics)
nickbrickmaster is an unknown quantity at this point
Bumpers do not count as part of the frame perimeter. You can't start the match with anything outside your perimeter. But otherwise yes, you may extend 15 inches outside your frame perimeter DURING the match.
I have approximate knowledge of many things.
FRC 3184: 2014-, FTC 10648: 2015-
Unread 01-10-2016, 01:12 AM
FRC #5202
Hah! I was debating putting that in my post to begin with. So just to confirm, it's fine, even though it would extend in front of the bumper?
Unread 01-10-2016, 01:16 AM
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
The rules you want to review are those regarding the Frame Perimeter (mainly R2-R4) and those regarding bumpers (mainly R19-R28). It's generally helpful to get in the habit of thinking of the rules in the language used in the manual, so you can be descriptive when asking about specific configurations.
Looking at your illustrations, it's hard to tell where the retracted position is relative to the Frame Perimeter, but the general concept seems to be within the scope of the rules.
-Gary Forbes
Unread 01-10-2016, 01:24 AM
FRC #5202
Yep. I checked those but I wasn't wholly sure.
The retracted piston would be within the frame perimeter, yes.
I'll be sure to keep that in mind for next time.
Thank you!
