Go to Post We're all human, we all make mistakes. How you deal with mistakes and problems, is what really elevates successful people, robotics teams, organizations, etc. above the rest. - artdutra04 [more]
Unread 10-01-2016, 08:27
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Stealing your opponents boulders
Originally Posted by bjtheone View Post
Not your fault they are feeding balls to you.
It's 100% your fault they are feeding balls to you that's kinda the point right?
That being said. All they need to do it throw a ball out of both EMBRASURE at once and you would get a foul for controlling multiple boulders!
Unread 10-01-2016, 12:26
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
Poorly phrased... "The fact that the requirement to put balls back into play results in them feeding you, does not mean you are forcing a fault", thus you don't trigger G11.
G38 needs clarification. If a ball ends up between you and the EMBRASURE due to your position relative to the EMBRASURE, is this "trapping" or "herding". You are not holding the BOULDER against a FIELD ELEMENT. They specifically state that "deflecting" is not "control".
