Go to Post You can learn a lot from making mistakes - even more from fixing them. - DarrinMunter [more]
Unread 10-01-2016, 10:10
gerthworm's Avatar
gerthworm gerthworm is offline
Making the 1's and 0's
FRC #1736 (Robot Casserole)
Rookie Year: 2015
gerthworm has a spectacular aura aboutgerthworm has a spectacular aura about
Re: Pneumatic Wheel Swerve
I helped with a pneumatic wheel swerve in college. We had a much higher weight limit and greater freedom in the choice of parts which helped a ton. Definitely possible, in general. However, the whole mechanism was still somewhat fragile - I'd be super worried this year about a module getting wedged in one of the defenses and burning out a motor. I wouldn't do it, but that's just me.
Edit: Here's some pictures of what we did: http://imgur.com/a/JkeBG
Unread 10-01-2016, 10:13
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
I actually ended up building a pneumatic swerve earlier in the fall. It worked but was heavy and really big. The wheels I ended up using were 8" diameter wheels from McMaster-Carr
Unread 10-01-2016, 12:17
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
So we might not be doing swerve, but for my own edification I'd like to know the key areas of stress in a swerve module. I assume there will be a cantilever force through the central axle as well as loads into the chassis and into the retaining bearings.
There will also be a force acting down and away from the axle protruding into the module, creating a pivot point.
I plan to isolate vertical shaft displacement with retaining clips and maybe even shaft collars, but I really don't know the numerical loads it will face. What have I missed? How in Solidworks can I get a stress analysis based off of the loads?
Cortechs Robotics 2014-Present
Mechanical, CAD
