Go to Post No, nothing secret unless you include the following: will it work?, can it be driven and will it release the balls. - twolf [more]
Unread 10-01-2016, 10:39
dmorewood's Avatar
dmorewood dmorewood is offline
Lead Designer / Coach
AKA: Drake Morewood
FRC #1218 (Vulcan)
Team Role: CAD
dmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nicedmorewood is just really nice
Low Bar
So after watching the game video a couple times I realized that you only need to destroy 4 of the 5 defenses to get a breach. This means that you would technically never have to deal with the Low Bar if you didn't want to. Do you think its still worth designing for your robot to go under the low bar if its unnecessary to get breaching points.
Unread 10-01-2016, 10:45
RPM24's Avatar
RPM24 RPM24 is offline
FRC #2202 (Beast robotics)
Team Role: Electrical
Rookie Year: 2015
RPM24 is an unknown quantity at this point
I wouldn't make it a priority. If it can then it can, if it can't, then that's not necessarily a big deal.
Unread 10-01-2016, 10:47
Green Potato Green Potato is offline
AKA: Tory Farmer
FRC #0422 (Mech Tech Dragons)
Team Role: Tactician
Green Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of lightGreen Potato is a glorious beacon of light
Re: Low Bar
Eh... maybe, maybe not. Can you fit under 16 inches and still make a shooter? You can, in theory, just ignore the low bar in a breach attempt, but what if there's one really tough obstacle out there? What if an alliance member gets stuck on one of the defenses? Is it worth the reduced cycle time? (it's right in front of the secret passage) Would it inhibit the climbing mechanism?
Such is the nature of strategy.
Everything that can go wrong WILL go wrong, except the things we expect to go wrong and actually plan for.
Unread 10-01-2016, 10:48
Lij2015's Avatar
Lij2015 Lij2015 is offline
I like turtles
AKA: Elijah Steele
FRC #2363 (Triple Helix)
Lij2015 has a spectacular aura aboutLij2015 has a spectacular aura about
Send a message via MSN to Lij2015
Re: Low Bar
In my opinion the low bar is the best way to design for. It's always on the field, you can do it speedily, and it allows for more high or low cycles (which in turns leads to a higher chance of destroying the tower).
There's nothing stopping you from putting attachments that when not extended are above 16 inches but when deployed can pass under it like a floor pickup or catapult.
Alumni turned volunteer!
2016 Chesapeake District volunteer, Scorekeeper/Game announcer.
Team 2363 Proud Alumni, Programmer/Driver 2013, 2014, 2015(Captain)
2016 Northern Virginia Winners (1418 and 2421)
2016 Hampton Roads Finalists(1885 and 5954)
2015 Chesapeake Regional Winners(1690 and 4050)
2015 Virginia Regional Winners(384 and 1610)
2014 Chesapeake Regional Winners(1629 and 623)
2013 Virginia Regional Finalists (3015 and 2053)
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Low Bar
Depends on your strategy.
1> The low bar is always in a known location (position 1).
2> It is the shortest route from your secret passage (where boulders are entered) to the enemies tower.
3> assuming others think as you are, you can add to an alliances capabilities by being able to damage that defense.
So, again ... it depends on your chosen strategy.
___________________
- Tennyson, Ulysses
