Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Unread 09-01-2016, 23:59
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
GRIP - Vision Processing
I was just messing around with GRIP and it is a very powerful tool. Does anyone know how to use the data it outputs. I've never messed with the networks table at all which is where it seems to output the data. Any help would be awesome!
Unread 10-01-2016, 10:56
Fauge7 Fauge7 is offline
Head programmer
FRC #3019 (firebird robotics)
Fauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to allFauge7 is a name known to all
Re: GRIP - Vision Processing
What language? i have messed around with network tables, specifically for vision actually...They are pretty simple to use...essentially if your robot is deciding if it should do ____ based on a value from a table it would look similar to this
table visiontable = NetworkTable.getTable("vision")
boolean shouldFire = visiontable.getvalue()
//rest of code
so while grip is powerful, its still in development...
Unread 10-01-2016, 11:01
The GRIP manual on Screensteps has an article for that:
http://wpilib.screenstepslive.com/s/...-networktables
Unread 10-01-2016, 14:41
Ok so that's how you access the data from grip but what can you do with that information?
Also would you have to have grip running on your computer with the driver station?
Unread 10-01-2016, 14:51
Head programmer
Since its java, it can be run anywhere! thats the beauty of it! It can run on your driverstaion, the rio or even a coprocessor, such an an odroid c1 (way better then raspi)
Unread 10-01-2016, 15:00
So I could take an ip camera from the robot and input that data into GRIP then output the data to the robot? If I had it running with the driver station. Also how do I use the information back
Unread 12-01-2016, 21:51
ThomasClark's Avatar
ThomasClark ThomasClark is offline
FRC #0237
ThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud ofThomasClark has much to be proud of
The C++ example on this page shows how to print the area and x/y coordinates of each target.
Assuming you're able to get this far, exactly how you use this data depends on your robot and your strategy. For example, if you're trying to like the robot up horizontally with the biggest target, you might do something like this. (This is a really oversimplified example, but hopefully it serves as a good starting point)
PHP Code:
const double CENTER_X 320.0;
const
double TOLERANCE_X 20.0;
void AutoShoot() {
    while (
true) {
auto areas grip->GetNumberArray("myContoursReport/area"llvm::ArrayRef<double>()),
xs    grip->GetNumberArray("myContoursReport/x",    llvm::ArrayRef<double>());
// Pick whatever target has the biggest area
double targetArea = -1.0targetX 0.0;
        for (
int i 0areas.size(); i++) {
            if (
areas[i] > targetArea) {
targetArea areas[i];
targetX xs[i];
// If we didn't find a target, return control to the operator
if (targetArea 0.0) {
            return;
// If we're too far to the left to shoot, move right.  If we're too far
        // to the right, move left.  If we're spot on, shoot and return.
if (targetX CENTER_X TOLERANCE_X) {
MoveRobotRight();
        } else if (
MoveRobotLeft();
        } else {
ShootBoulder();
            return;
GRIP (Graphically Represented Image Processing) - rapidly develop computer vision algorithms for FRC
Unread 14-01-2016, 21:02
hewittalec hewittalec is offline
FRC #0058
hewittalec is an unknown quantity at this point
Hello. Just started using GRIP. Is it possible to run grip from my drivers station PC by getting the robot USB camera feed? If so how do I send the Network Table data back to the roboRio for my program?
Thanks
