Go to Post If you don't like getting tipped don't build a robot that tips. - Koko Ed [more]
Unread 10-01-2016, 12:41
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
G43 loophole
G43 seems to have a loophole.
If you are in contact with a defense, but your bumpers are not breaking the plane of the outer works (for instance, you have grabbed the top of the drawbridge and are pulling it down by backing away from the outer works), are you still protected? The way the rules are now written I don't think so.
That means that once a robot begins opening the category C defenses, as soon as its bumper clears the plane of the outer works, you can ram them away from the defense.
I expect that to be rectified in a team update.
Former Mentor Team 1771
Former mentor Team 4509
Unread 10-01-2016, 13:17
AndyBare AndyBare is offline
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: G43 loophole
G43: ROBOTS on the same half of the FIELD as their ALLIANCE TOWER may not interfere with opponent ROBOTS attempting to traverse OUTER WORKS (regardless of direction). A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS.
So by this, we know that "A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS."
But the rule, however, also states that "You may not interfere with opponent ROBOTS attempting to traverse. It doesn't say they have to be traversing. If they're in contact with a defense, I think it will be obvious that they're "attempting to traverse" the outer-works.
Hope maybe that this clarifies the issues with how the rule is worded?
Andy Bare
Team 1261
Unread 10-01-2016, 13:34
martin417's Avatar
AKA: Martin Wilson
Re: G43 loophole
I understand the wording, including the "attempting to traverse". Also, I believe the intent of the rule is to not allow such defense. However, the way "traversing" is defined is very specific.:
So, conversely, if no part of the robot's bumpers are within the opponent's outer works (also clearly defined in the rules) then they are not traversing, and therefore not protected.
Unread 10-01-2016, 14:09
Pongox's Avatar
Pongox Pongox is offline
Videographer and Mechanical
AKA: Ian
FRC #2067 (Apple Pi)
Team Role: Photography
Rookie Year: 2015
Pongox is an unknown quantity at this point
Re: G43 loophole
True, but as AndyBare said, the robot does not have to be traversing the defense, only attempting to traverse.
Unread 10-01-2016, 14:34
nick4130 nick4130 is offline
4130 Mechanical Lead
AKA: Nick
FRC #4130 (The Blue Devils)
Team Role: Human Player
Rookie Year: 2015
nick4130 is an unknown quantity at this point
Re: G43 loophole
Wow this is Intresting
Unread 10-01-2016, 14:57
martin417's Avatar
AKA: Martin Wilson
Re: G43 loophole
Please read the definition of traversing (highlighted in red above)
Unread 10-01-2016, 15:17
Re: G43 loophole
But all you need to do is attempt to traverse. He understands that.
Andy Bare
Team 1261
Unread 10-01-2016, 15:26
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: G43 loophole
How you define "attempting" could be very different than he does though. Does the lead up to a traverse fall under "attempting"? What about when you fail a traverse? When does the "attempt" end?
Unread 10-01-2016, 15:47
Tymethy's Avatar
Tymethy Tymethy is offline
Scouting Captain
AKA: Tymothy
FRC #3824
Tymethy is an unknown quantity at this point
Re: G43 loophole
They should be protected under 3.1.3 where it goes more into detail what crossing is it states:
"A DEFENSE is CROSSED by a ROBOT when that ROBOT
■ starts free of contact with the DEFENSE and completely in the NEUTRAL ZONE"
So the robot is also in the process of crossing if it is not "free of contact with the DEFENSE" so the robot is then protected.
Unread 10-01-2016, 15:48
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: G43 loophole
Note: If you have an extension that is holding the door open, and that extension is in the Outerworks, then the robot is in the outerworks.
Note2: The door does extend into the neutral zone, so there could be a time when the robot is full outside of Outerworks, yet still in contact with the defense.
Maybe a Q&A requesting a clarification that robot is "in the outerworks" or "in contact with the defense".
Unread 10-01-2016, 16:33
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Re: G43 loophole
They define traversing in the rule and according to that definition contact alone is not traversing. Only breaking the plane of the outer works is defined as traversing. Here is the pertinent line
If you backup to pull down the bridge you are no longer breaking the plane of the outer works
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 10-01-2016, 16:52
Re: G43 loophole
But would you agree that pulling a gate down in an attempt to traverse the outer works is "attempting to traverse"? That's the key.
Andy Bare
Team 1261
Unread 10-01-2016, 17:03
cmwilson13's Avatar
Re: G43 loophole
No. They defined traversing and contact is not listed anywhere
Unread 10-01-2016, 17:11
martin417's Avatar
AKA: Martin Wilson
Re: G43 loophole
Since there is no definition in the rules for "attempting to traverse", then "attempting" has no meaning withing the rules.
So, how does a ref decide if a robot is "attempting"? Is moving towards the defense attempting? It could be, because The robot is attempting to get to the outer works. There is no way the GDC will allow such an ambiguous definition to stand. Expect a team update where they include "contacting any part of the defense" to the definition of "traversing".
Unread 10-01-2016, 17:15
Re: G43 loophole
Bingo
Andy Bare
Team 1261
