Go to Post I could say that the decline in the population of pirates is responsible for global warming, the statistics correlate, but its obvious there's no causation there. - Racer26 [more]
Unread 10-01-2016, 14:47
sgoldman sgoldman is offline
FRC #3807
sgoldman is an unknown quantity at this point
Robot Extension Limitations
Rules G18 and R3 state: "ROBOTS may not extend greater than 15 in. beyond the FRAME PERIMETER. Violation: FOUL"
My team was curious if this applied to the potential extension of parts, or just what extends in a match. For example, if we were to have an arm that manipulates obstacles during a match and telescopes up at the end to scale the castle (not our exact thoughts, just theoretical), it could extend 15 inches beyond the perimeter during the match, but won't. Would this pass inspection?
Thanks in advance for your help!
Unread 10-01-2016, 14:52
Zach101's Avatar
Zach101 Zach101 is offline
Oh captain, my captain
AKA: Zach Hagen
FRC #2512 (Duluth East Daredevils)
Team Role: Tactician
Zach101 has a spectacular aura aboutZach101 has a spectacular aura aboutZach101 has a spectacular aura about
Re: Robot Extension Limitations
If I am taking this question right.... As long as that part doesn't extend past 15 during telop you should be good. Even if it has the potential to go past 15 inches to climb during the end game I don't see anything wrong with it.
2015 MSHSL State Championship Winners with 3130 and 4215
2015 Hopper Division Winners & Einstein Finalists with 987, 2826, and 4265
2015 Northern Lights Chairman's Award Winners
Finalists at the 2015 Central Illinois Regional with 4143 and 4212
Finalists at the 2015 Northern Lights Regional with 5172 and 4786
2015 Prior Lake Mini Regional Winners with 2169 and 4859
2014:Strategy 2015:Electrical 2016:Strategy Captain
<Hopper Division Announcer> 'When I said Admiral, you say Hopper... Admiral! Ackbar!
Unread 10-01-2016, 14:58
Zach101's Avatar
AKA: Zach Hagen
Though here is my comment because I might see a way you can mistake my earlier reply. That potential extension part may only go longer than 15 inches as long as it during end game(last 20 seconds) and extending past 15 inches upward not horizontally.
Unread 10-01-2016, 15:27
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Read rule R3 and note the blue box underneath it. Your inspector should ask how you're going to prevent it from extending more than 15" horizontally. If you have, for example, a SW lock that uses game time from FMS to lock out the function that extends it vertically, you'd probably be good.
I'm having trouble visualizing how something like this would work, so I can't really say for sure. I suspect that even without some kind of SW lock you'd probably pass, but if so the LRI would tell the Head Ref about it, saying "it passed inspection but it might violate G18 if they're not careful."
Mentor http://www.teamtitanium.org/
Unread 10-01-2016, 15:45
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Note: The 15" rule is for the horizontal plane from the base of your robot.
The frame perimeter does not limit the height of the robot. There are other rules that do that.
Unread 10-01-2016, 19:46
221Sarahborg's Avatar
221Sarahborg 221Sarahborg is offline
Alumna Mentor
AKA: Sarah S.
FRC #1810 (Jaguar Robotics)
221Sarahborg is an unknown quantity at this point
By the description of that theoretical part of the robot, I believe our team has also looked into that strategy. I think the simple option would be to just make sure it cannot extend 15" outside of the robot's perimeter. You could either build it so it can't or maybe implement a limit switch?
KU SADP
1810 - Jaguar Robotics
Alumna Mentor for Electrical & Driving
Team Website & Twitter
Unread 10-01-2016, 20:01
jds2001 jds2001 is offline
AKA: Jon Stanley
FRC #4263 (CyberDrgaon)
jds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud ofjds2001 has much to be proud of
Again, I see no exceptions for the robot extension during the end game. The only exception granted is to the height limitation (which is ordinarily 54 inches). Also note the rules for the STARTING CONFIGURATION (R4) which says that you may not extend outside the vertical projection of the FRAME PERIMETER - i.e. draw a box infinitely high with the FRAME PERIMETER and you may not break that plane with any part of your robot.
- Official Scorer
Disclaimer: I volunteer for FIRST as a referee. All opinions are my own, and do not reflect those of FIRST.
Unread 10-01-2016, 20:09
Alumna Mentor
AKA: Sarah S.
In 3.4.5 it starts with G17 which states the robot must stay in the 54" height on a flat floor "except during the final twenty (20) seconds of TELEOP where there is no heigh limit when a ROBOT is fully contained by the opponent's COURTYARD."
Then on the next page it has G18, "ROBOTS may not extend more than 15. in beyond their FRAME PERIMETER." Which leads me to believe that if they only referred to it for the vertical limit but not the horizontal which directly follows it, so I would think the 15" follows through to the last 20 seconds. I do tend to give unnecessary restrictions if I'm not sure, but possibly they may clear that up in a future manual update.
KU SADP
Unread 17-01-2016, 19:11
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
I'm curious, does a cumulative 15 inches apply to all protrusions from the frame perimeter, or can there be multiple extensions from the frame perimeter cumulatively totaling more than 15 inches? i.e. dual intakes or wings at 14" each.
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 17-01-2016, 19:22
bjtheone bjtheone is offline
Design and Fab guy
AKA: Brad Warkentin
FRC #2706 (Merge Conflict)
bjtheone is an unknown quantity at this point
G18 is clarified with drawings (Fig 3-2) in update-02. The 15" stays in effect throughout the entire match. The plane of measurement is the orientation of the drive base. Therefore you cannot have a climbing mechanism that extends outside of the magic 15". As mentioned before, there are no height restrictions in the last 20 seconds of TELEOP.
The practical application of this rules means you need to maintain your horizontal orientation while SCALING the TOWER, or you will likely violate it and be DISABLED.
Unread 17-01-2016, 19:30
Design and Fab guy
AKA: Brad Warkentin
No rules against multiple protrusions so it is legal.
Read and reread the last paragraph of Section 1.4. If you can come up with a brilliant and unorthodox strategy that is not against the rules and requirements it is ok. The only risk you run is that if it a somewhat obvious "loophole" of the game intent, it may be closed in an update.
The intent of this manual is that the text means exactly, and only, what it says. Please avoid interpreting the
text based on assumptions about intent, implementation of past rules, or how a situation might be in “real
life.” There are no hidden requirements or restrictions. If you’ve read everything, you know everything.
Unread 17-01-2016, 19:31
Q&A clarified that one, too. 15" is the limit, but you can have multiple extensions within that limit.
Basically, the 15" is a distance from the Frame Perimeter. Stay inside it with anything you have out, and you're good. If something (one thing) goes over, penalties ensue of varying degrees.
