Re: SmartDashboard Crash
Hello, I am having the same issue where as soon as you launch the driver station and the smartdashboard loads, it crashes. I have tried reinstalling the c++ toolchain, and the deleting the eclipse plugins and reinstalling them.
Here are the logs from running Joe's suggestions Java version: Code:
C:\Users\tigertronics>java -version java version "1.8.0_25" Java(TM) SE Runtime Environment (build 1.8.0_25-b18) Java HotSpot(TM) 64-Bit Server VM (build 25.25-b02, mixed mode) Code:
C:\Users\tigertronics>java -jar C:\users\tigertronics\wpilib\tools\smartdashboar
d.jar
No Extension Folder
platform: /Windows/amd64/
Jan 10, 2016 2:55:27 PM java.util.prefs.WindowsPreferences <init>
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0
x80000002. Windows RegCreateKeyEx(...) returned error code 5.
NT: connect() to port 1735 timed out
Host: roboRIO-2053-frc.local
Loading from C:\Users\tigertronics\SmartDashboard\save.xml
Loading SmartDashboard widgets....
java.lang.reflect.InvocationTargetException
at java.awt.EventQueue.invokeAndWait(Unknown Source)
at javax.swing.SwingUtilities.invokeAndWait(Unknown Source)
at edu.wpi.first.smartdashboard.main.main(main.java:111)
Caused by: java.lang.NoSuchMethodError: org.jfree.ui.RectangleInsets.<init>(DDDD
)V
at org.jfree.chart.axis.Axis.<clinit>(Axis.java:136)
at org.jfree.chart.ChartFactory.createXYLineChart(ChartFactory.java:1525
at edu.wpi.first.smartdashboard.gui.elements.LinePlot.init(LinePlot.java
:36)
at edu.wpi.first.smartdashboard.gui.DashboardPanel.addElement(DashboardP
anel.java:268)
at edu.wpi.first.smartdashboard.gui.DashboardPanel.setField(DashboardPan
el.java:327)
at edu.wpi.first.smartdashboard.gui.DashboardFrame.load(DashboardFrame.j
ava:304)
at edu.wpi.first.smartdashboard.main$3.run(main.java:124)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEventImpl(Unknown Source)
at java.awt.EventQueue.access$400(Unknown Source)
at java.awt.EventQueue$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(Unknown Sour
ce)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source)
at java.awt.EventDispatchThread.pumpEvents(Unknown Source)
at java.awt.EventDispatchThread.run(Unknown Source)
Thanks |
Alright, I figured it out. The reason the smartdashboard crashes is because you are using an old dashboard save from last year. To fix this just navigate to:
C:\Users\"user"\SmartDashboard Then it should work,. However, I ran into another issue when formatting different values on the smartdashboard. Whenever I try to change a simple text box to a line plot or simple dial, the value disappears and does not show up again until you reboot the dashboard. When it does reappear, it is just in a text box again. If anyone can reproduce this issue or has suggestions, please respond. |
any idea when the patch will come out as part of an update?
