Go to Post And like Woodie told us in his talk, all the bad stuff we anguished over will be replaced by the memories of the achievements and good time we had this year. - Wayne C. [more]
Unread 10-01-2016, 14:57
martin417's Avatar
Opinionated old goat
AKA: Martin Wilson
Re: G43 loophole
Originally Posted by Pongox View Post
True, but as AndyBare said, the robot does not have to be traversing the defense, only attempting to traverse.
Please read the definition of traversing (highlighted in red above)
Former Mentor Team 1771
Former mentor Team 4509
Unread 10-01-2016, 15:17
AndyBare AndyBare is offline
CAD Design and CNC Machinist
FRC #1261 (Robo Lions)
AndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of lightAndyBare is a glorious beacon of light
Re: G43 loophole
But all you need to do is attempt to traverse. He understands that.
Unread 10-01-2016, 15:26
Monochron's Avatar
Monochron Monochron is offline
Engineering Mentor
AKA: Brian O'Sullivan
FRC #4561 (TerrorBytes)
Monochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond reputeMonochron has a reputation beyond repute
Re: G43 loophole
How you define "attempting" could be very different than he does though. Does the lead up to a traverse fall under "attempting"? What about when you fail a traverse? When does the "attempt" end?
Unread 10-01-2016, 15:48
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Re: G43 loophole
Note: If you have an extension that is holding the door open, and that extension is in the Outerworks, then the robot is in the outerworks.
Note2: The door does extend into the neutral zone, so there could be a time when the robot is full outside of Outerworks, yet still in contact with the defense.
Maybe a Q&A requesting a clarification that robot is "in the outerworks" or "in contact with the defense".
Unread 11-01-2016, 05:33
martin417's Avatar
AKA: Martin Wilson
Re: G43 loophole
Read the definition again, carefully. The definition explicitly says a robot is traversing if "any part of its BUMPERS are within the opponent’s OUTER WORKS."
An extension is not a bumper.
Unread 11-01-2016, 07:05
Re: G43 loophole
Name the robot "Its bumpers." I've solved it!
Unread 11-01-2016, 12:31
GeeTwo's Avatar
GeeTwo GeeTwo is offline
Technical Director
AKA: Gus Michel II
FRC #3946 (Tiger Robotics)
Re: G43 loophole
My understanding: Once the robot bumpers enter the outer works, the traversal attempt has begun. As you pull the door down and back out of the outer works, because the traversal is defined such that you start not in contact with the defense, the traversal attempt continues.
Still need a GDC confirmation.
Unread 11-01-2016, 14:58
DKolberg DKolberg is offline
Mentor Iron Giants
AKA: David Kolberg
FRC #5069 (Iron Giants)
DKolberg has a spectacular aura aboutDKolberg has a spectacular aura about
Re: G43 loophole
I would think that when you pull down the drawbridge, the part you run over is still part of the outerworks and therefore you can not hit someone.
David Kolberg
2014- Mentor Iron Giants 5069
2004-2010 Coach SBotz Team 1327
2000-2003 Mentor Team 135
2016 St. Joe District Event Winner
2009 WFA Boilermaker
2008 Driving Tomorrow's Technology
2005 Innovation in Control
2005 IRI Spirit of Indiana
Unread 11-01-2016, 15:21
Re: G43 loophole
Nope. The part of the drawbridge does not extend Outer Works into the Neutral Zone.
Unread 11-01-2016, 19:25
GaryVoshol's Avatar
Cogito ergo arbitro
Re: G43 loophole
A good reasonable interpretation - can you confirm with Q&A when it opens? Because reasonable or not, until the GDC says you're right, you're not right.
(I'm just a lowly head ref not on a team so I don't have Q&A asking rights.)
(since 2004)
Unread 10-01-2016, 16:33
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
FRC #1771 (N. G. R.)
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
Re: G43 loophole
They define traversing in the rule and according to that definition contact alone is not traversing. Only breaking the plane of the outer works is defined as traversing. Here is the pertinent line
A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS.
If you backup to pull down the bridge you are no longer breaking the plane of the outer works
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014- Future
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
Unread 10-01-2016, 16:52
Re: G43 loophole
But would you agree that pulling a gate down in an attempt to traverse the outer works is "attempting to traverse"? That's the key.
Unread 10-01-2016, 17:03
cmwilson13's Avatar
Re: G43 loophole
No. They defined traversing and contact is not listed anywhere
Unread 10-01-2016, 17:11
martin417's Avatar
AKA: Martin Wilson
Re: G43 loophole
Since there is no definition in the rules for "attempting to traverse", then "attempting" has no meaning withing the rules.
So, how does a ref decide if a robot is "attempting"? Is moving towards the defense attempting? It could be, because The robot is attempting to get to the outer works. There is no way the GDC will allow such an ambiguous definition to stand. Expect a team update where they include "contacting any part of the defense" to the definition of "traversing".
Unread 10-01-2016, 17:15
Re: G43 loophole
Bingo
