Re: G43 loophole
But all you need to do is attempt to traverse. He understands that.
Re: G43 loophole
How you define "attempting" could be very different than he does though. Does the lead up to a traverse fall under "attempting"? What about when you fail a traverse? When does the "attempt" end?
Re: G43 loophole
Note: If you have an extension that is holding the door open, and that extension is in the Outerworks, then the robot is in the outerworks.
Note2: The door does extend into the neutral zone, so there could be a time when the robot is full outside of Outerworks, yet still in contact with the defense. Maybe a Q&A requesting a clarification that robot is "in the outerworks" or "in contact with the defense". |
Re: G43 loophole
An extension is not a bumper. |
Re: G43 loophole
Name the robot "Its bumpers." I've solved it!
Re: G43 loophole
My understanding: Once the robot bumpers enter the outer works, the traversal attempt has begun. As you pull the door down and back out of the outer works, because the traversal is defined such that you start not in contact with the defense, the traversal attempt continues.
Still need a GDC confirmation. |
#7
Re: G43 loophole
I would think that when you pull down the drawbridge, the part you run over is still part of the outerworks and therefore you can not hit someone.
#8
Re: G43 loophole
Nope. The part of the drawbridge does not extend Outer Works into the Neutral Zone.
#9
Re: G43 loophole
(I'm just a lowly head ref not on a team so I don't have Q&A asking rights.) |
#10
Re: G43 loophole
A ROBOT is considered traversing the opponent’s OUTER WORKS if any part of its BUMPERS are within the opponent’s OUTER WORKS. If you backup to pull down the bridge you are no longer breaking the plane of the outer works |
#11
Re: G43 loophole
Re: G43 loophole
No. They defined traversing and contact is not listed anywhere
#13
Re: G43 loophole
Since there is no definition in the rules for "attempting to traverse", then "attempting" has no meaning withing the rules.
So, how does a ref decide if a robot is "attempting"? Is moving towards the defense attempting? It could be, because The robot is attempting to get to the outer works. There is no way the GDC will allow such an ambiguous definition to stand. Expect a team update where they include "contacting any part of the defense" to the definition of "traversing". Last edited by martin417 : 10-01-2016 at 17:22. |
#14
Re: G43 loophole
Bingo
#15
Re: G43 loophole
I very much hope so.
