Go to Post I heard a Lou Holtz quote as an answer to the question of "how do you motivate the unmotivated". He said " You eliminate those who are not motivated." - Scott Ritchie [more]
Unread 10-01-2016, 13:40
BrandonD-1528's Avatar
BrandonD-1528 BrandonD-1528 is offline
AKA: Brandon Dusseau
FRC #1528 (Monroe Trojan Robotics)
BrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the roughBrandonD-1528 is a jewel in the rough
FMS-OBS Integration
First, some background. I'm working out details on upgrades to our broadcasting equipment at the Michigan Advanced Robotics Competition this year. I'd like to develop a more advanced audience display to integrate into Open Broadcaster for the web stream (and hopefully displays at the event itself), but I'm going to need some help in order to achieve it.
I'm looking for anyone who has knowledge of FMS to discuss possibilities for hooking into its match data in real-time. I know that the system runs on an MSSQL database and in the worst case I might be able to get the admins to create a read-only user and tie into that. I'm hoping to find out if there are more convenient event-based hooks in the software, however.
I know that custom audience displays are possible - we used one a couple years ago, but it displayed locally and we had to use a scan converter to fetch the video signal from FMS. I want to explore the possibility of expanding upon that with a daemon that will transmit data across the local network, so that hopefully we have an easily customizable display that we can run in HD.
So, if you know anything about this topic, any replies would be greatly appreciated. If this isn't something we can talk about in the open, I'm open to private messages as well.
Please keep in mind that this is all just ideas at this point. If we don't have time to get and test the equipment I'll just fall back to the "legacy" broadcasting setup we have now.
Thanks!
Brandon Dusseau (website)
Monroe Trojan Robotics mentor
Software Engineer
Michigan Tech alumnus
Unread 10-01-2016, 13:50
Schnabel's Avatar
Schnabel Schnabel is offline
Seriously I'm almost never serious!
AKA: Eric Schnabel
FRC #0469
Schnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond reputeSchnabel has a reputation beyond repute
Re: FMS-OBS Integration
This is probably the best way you can get to real time data during the season. Note that this information is not available in off-season.
http://docs.frcevents2.apiary.io/#
I win! XD
Unread 10-01-2016, 13:51
Thanks, but this is for an off-season event, and I need data while the match is in play. I'm entirely replacing the audience view that we use.
Software Engineer
Unread 10-01-2016, 13:52
plnyyanks's Avatar
plnyyanks plnyyanks is online now
Data wins arguments.
AKA: Phil Lopreiato
Use Cheesy Arena and modify its (open source) audience display?
Unread 10-01-2016, 13:55
I'd prefer not to interfere with the FMS setup that FIRST in Michigan already has in place, beyond installing my own software to interface with it.
Software Engineer
Unread 10-01-2016, 14:45
Doug Frisk's Avatar
Doug Frisk Doug Frisk is online now
Keeping Score
AKA: Doug Frisk
Doug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond reputeDoug Frisk has a reputation beyond repute
There is no way to query the FMS data directly even if you are on the same network.
Unread 10-01-2016, 14:47
I was more planning on having an application running alongside FMS that will transmit the data to a client. The issue is finding the best way for the server to integrate with FMS' data. Accessing the SQL database is one option but I'm hoping there's a better way.
Software Engineer
Unread 10-01-2016, 14:49
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
I would think that installing anything on the FMS would be, let's say, frowned upon.
Unread 10-01-2016, 14:59
That would certainly be the case in season events. Being that this is a large off-season event and everything would be done under the supervision of the FTAs, I don't see a problem. We've certainly had custom audience view software running on it before.
Software Engineer
Unread 10-01-2016, 15:12
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
Well, if I were going to approach this, rather than touching the FMS I'd look into impersonating the Azure back end. Of course then you'd have to have the in-season software not the post season software that disables syncing. That way as soon as the scorekeeper hit commit you'd have updated data. It would require a bit of networking and coding legerdemain but if it were accomplished it would be transparent on the FMS itself.
Unread 10-01-2016, 15:13
That's an interesting idea. That wouldn't enable live score display mid-match (for the lower third) though, would it?
Software Engineer
Unread 10-01-2016, 15:14
Doug Frisk's Avatar
Keeping Score
AKA: Doug Frisk
No.
Unread 10-01-2016, 15:15
Also, is it at all possible to set up my own FMS environment to see how it works? I don't really know if the software has been made available.
Software Engineer
Unread 10-01-2016, 15:44
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
Team Role: Electrical
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
I know it is possible to get some data from the FMS (at least it was two years ago).
In 2014 we used a combination of a quasi light FMS to control the robots, with a bunch of custom software that would monitor the FMS and automatically start the custom hot goal and scoring software at the same time as the rest of the match.
My advice would be to get a copy of the off-season FMS and have a look with wireshark to see what you can get. See what packets are transmitted at match start, when you queue up a match, when you push scores etc.
You can also probably grab scores, rankings, team numbers and anything else on the standard display, as these are transmitted on the network to work with some of the audience displays.
Good Luck!
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 10-01-2016, 15:46
That information is immensely helpful, thank you. Do you happen to know how I can get my hands on the off-season FMS?
Software Engineer
