Re: G43 loophole
Note: If you have an extension that is holding the door open, and that extension is in the Outerworks, then the robot is in the outerworks.
Note2: The door does extend into the neutral zone, so there could be a time when the robot is full outside of Outerworks, yet still in contact with the defense. Maybe a Q&A requesting a clarification that robot is "in the outerworks" or "in contact with the defense". |
Re: G43 loophole
An extension is not a bumper. |
Re: G43 loophole
Name the robot "Its bumpers." I've solved it!
Re: G43 loophole
My understanding: Once the robot bumpers enter the outer works, the traversal attempt has begun. As you pull the door down and back out of the outer works, because the traversal is defined such that you start not in contact with the defense, the traversal attempt continues.
Still need a GDC confirmation. |
Re: G43 loophole
I would think that when you pull down the drawbridge, the part you run over is still part of the outerworks and therefore you can not hit someone.
Re: G43 loophole
Nope. The part of the drawbridge does not extend Outer Works into the Neutral Zone.
#7
Re: G43 loophole
(I'm just a lowly head ref not on a team so I don't have Q&A asking rights.) |
