Go to Post “I hope you all had a good weekend. If you didn’t you can try again in five days.” -Honors Debate teacher - Joe J. [more]
Unread 10-01-2016, 20:53
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
Rotation of a part independent of the base
Excuse the MS paint, but:
Is it possible to isolate the yaw of the cylinder on this prism?
More clearly: Is there a mechanical way to have the rectangular prism rotate but the cylinder will not follow it?
For example, the entire system is facing north. The rectangular prism (robot) turns south, but the cylinder has not rotated at all. For any other non-rotation movement, the cylinder obviously still follows. So if it drives north, the cylinder will stay attached and come north with it.
edit: Please purely mechanical, with no gyro sensors etc
Unread 10-01-2016, 20:58
rzoeller rzoeller is offline
MN GOFIRST Recruitment Officer
AKA: Ryan Zoeller
FRC #2169 (RI3D 'Snow Problem; KING TeC)
rzoeller is a jewel in the roughrzoeller is a jewel in the roughrzoeller is a jewel in the rough
Re: Rotation of a part independent of the base
Easiest thing I can think of is to put the cylinder on a Lazy Susan, and hook it up to a motor to turn. Mount a gyroscope to the cylinder, and use something like PID to drive the rotation of it back to zero continuously.
Ri3D - 'Snow Problem Programmer
FRC 2169 Alumni
jimbo493's Avatar
jimbo493 jimbo493 is offline
Quasi Mentor
AKA: Jimmy
FRC #3357 (The COMETS)
Team Role: Electrical
jimbo493 is on a distinguished road
You could use an accelerometer/gyro like the navX board to track the prism, and have a slew ring with a motor to turn the cylinder opposite of the prism. Assuming that the prim is the robot and the cylinder would presumably be a mechanism.
EDIT: rzoeller beat me to it
FTC Student 2011-2012 FRC Student 2012-2016
FIRST Alum/Quasi-Mentor 2016-present
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
Well, I guess you could put a gyro on the cylindrical component, and assuming the cylindrical thing is on a motor, have it on a closed-loop system to keep it facing at a constant angle.
But maybe that's not what you're looking for if you want something purely mechanical.
Edit: someone beat me to it
Head Programmer / Driver
Unread 10-01-2016, 20:59
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
Mount the cylinder on a pivot (like a lazy susan), and turn it with a motor, utilizing feedback from a gyro (or a camera if there's something to track on, like one of the goals). It requires some good code to make it work right, but teams have definitely done it before. I have a copy of the Behind the Design book for Aim High next to me, and there's some significant discussion in it about using and controlling a rotating turret for shooting balls.
2016: Lake Superior WFFA
Yes, I am looking for pure mechanical. The only way I can think of is to have the cylinder floating on a small reservoir of water, but I am pretty sure that'd not allowed.
Unread 10-01-2016, 21:01
AKA: Ryan Zoeller
Without strengthening the Earth's magnetic field, I can't think of a better way.
FRC 2169 Alumni
Unread 10-01-2016, 21:04
jimbo493's Avatar
Quasi Mentor
AKA: Jimmy
if you had a swerve type drive you could link of a steering module in some way shape or form, but it would only work in certain turning situations, and is pretty complicated. The best way is probably to just use a gryo, it sound complicated, but is way simpler than a mechanical system, which in itself is not very feasible
Unread 10-01-2016, 21:05
menns menns is offline
AKA: Michel Enns
FRC #1310 (Runnymede Robotics)
menns has a spectacular aura aboutmenns has a spectacular aura about
I was going to suggest floating it in mercury but aluminum and mercury don't get along so well.
Unread 10-01-2016, 21:07
But hey, maybe the reservoir wouldn't count as a switch or contact!!!
Unread 10-01-2016, 21:08
AKA: Ryan Zoeller
See part G
FRC 2169 Alumni
Unread 10-01-2016, 21:09
kitare102 kitare102 is offline
AKA: Eric
FRC #3042 (Cobalt Catalysts)
kitare102 is an unknown quantity at this point
If I understand you correctly, the mechanism you're going after is effectively this: https://en.wikipedia.org/wiki/South-pointing_chariot
It's ancient technology, but I'm sure the principles at work hold true. However, I'd be cautious with this design, as any slippage of the wheels while going over obstacles will introduce some amount of drift from the original direction.
I can't think of any other design that won't require sensor input. Your idea of floating in water has its problems aside from legality, seeing as any jostle will start it spinning. I don't see any use for a cylinder which points a certain direction but can't affect anything else.
I'm interested why you don't want to utilize a gryo/other sensor, seeing as they're by far to most mainstream way of monitoring direction.
Unread 10-01-2016, 21:10
OK maybe we will do it with a gyro then. How would I keep the gyro accurate after we are bumping around over things like the rough terrain, etc? Would it stay accurate within say, 2 degrees over the course of a match?
Unread 10-01-2016, 21:12
AKA: Ryan Zoeller
It will drift - the exact amount will depend on how much jostling around you do. I would recommend adding a potentiometer or some sort of feedback mechanism (even just a button based trim control) to correct for when it does drift, i.e. keep a counter that you add/subtract from the reported value based on driver feedback.
FRC 2169 Alumni
Unread 10-01-2016, 21:13
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If the bearing supporting the cylinder has no friction, then it will behave like you want. Also, if it has very little friction, and there is a lot of inertia in the cylinder, it will mostly behave like you want.
When I was a youngster, gyroscopes were mechanical....they had a part that spun very fast, and it was mounted in a gimble, on low friction bearings. Look it up. Maybe you could do something like that.
But my guess is that you might be able to think of other ways to play the game, that don't require so much fun design and fabrication work.
