Go to Post I'm sure there aren't a bunch of rule makers sitting in a board room discussing "What rule can we change now to mess with the teams' heads?" Lets all just sit back and enjoy the regionals! - Rick [more]
Unread 10-01-2016, 21:15
KyloRen42 KyloRen42 is offline
KyloRen42 is an unknown quantity at this point
Re: Rotation of a part independent of the base
Originally Posted by rzoeller View Post
It will drift - the exact amount will depend on how much jostling around you do. I would recommend adding a potentiometer or some sort of feedback mechanism (even just a button based trim control) to correct for when it does drift, i.e. keep a counter that you add/subtract from the reported value based on driver feedback.
If you've used gyros before, could you give me an example of how bad it could drift?
