Go to Post By the end of week six, I'm sick of looking at the robot enough that stuffing it in a bag is rather cathartic...:rolleyes: - 2544HCRC [more]
Unread 10-01-2016, 14:22
Pongox's Avatar
Pongox Pongox is offline
Videographer and Mechanical
AKA: Ian
FRC #2067 (Apple Pi)
Team Role: Photography
Rookie Year: 2015
Pongox is an unknown quantity at this point
Robot intentionally tipping over
Rule G25 states:
A ROBOT may not attempt to stop or impede the flow of the MATCH in any of the following ways:
A. intentionally tipping over
B. coordinating a blockade of the FIELD with ALLIANCE members
C. blocking GOAL(S) while in contact with its own BATTER using anything outside its FRAME PERIMETER
So could you intentionally tip the robot over without trying to impede the flow of the match?
Unread 10-01-2016, 14:33
John Retkowski's Avatar
John Retkowski John Retkowski is offline
Team 316 mentor
AKA: Wyatt. Call me Wyatt.
FRC #0316 (LuNaTeCs)
John Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of lightJohn Retkowski is a glorious beacon of light
Re: Robot intentionally tipping over
Why would you want to tip over? If you mean tipping over to block a goal or a defense, I would consider those to be impeding the flow of the match.
2015 MAR District Championship #1 seed Winners (w 225 & 203)
2015 Upper Darby District #2 Seed Finalist(w 272 & 5420)
2015 NE Pioneer Valley District #3 Seed Finalists (w 61 & 663)
2014 Lenape Seneca District Champions (w 3929 & 2559)
2014 Springside Chestnut Hill District Champions (w 225 & 1495)
2013 Lenape Seneca District Champions
2013 Springside Chestnut Hill Finalists
Unread 10-01-2016, 14:36
Pongox's Avatar
AKA: Ian
Rookie Year: 2015
I was thinking about a way for a tall but thin robot to go under the low bar. I was just curious about this method.
Unread 10-01-2016, 14:39
Team 316 mentor
I would THINK you would then have to then look at the 120 inch frame rule because there have been instances (last year I believe) where it was then considered to be changing configuration and then the height would be considered the "frame perimeter."
Unread 10-01-2016, 14:46
Neil Neil is offline
FRC #1261 (Robo Lions)
Team Role: Student
Rookie Year: 2016
Neil is an unknown quantity at this point
Notice "stop or impede the flow of the MATCH". If it is intentional, and part of your strategy, then the judges may consider it ok. It may vary judge to judge, however. After tipping over, it may be difficult to get back up, which may limit it's functionality. You may want to look into G18, which limits the robot from extending 15in past its perimeter.
Unread 10-01-2016, 15:04
samfruth's Avatar
samfruth samfruth is offline
FRC #1710 (Ravonics Revolution)
Team Role: Driver
samfruth will become famous soon enough
I was thinking the same thing. Using this method, you could theoretically get a robot taller than 1' 4" through under the low bar. I was thinking an "L" design with wheels on both sides. I could see perimeter stuff causing an issue though.
I kind of know programming
Unread 10-01-2016, 15:15
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
You'd need retractable wheels to clear the bumpers. Also, even with some sort "training wheel" type device (within 15"), that would be an awful tippy robot being so narrow. Can be done, but IMHO this sounds like a bad life-alert commercial in the making ("Help, I can't get up!!!").
Unread 10-01-2016, 21:02
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
This has little to do with the rule, but please note the difference between judges and referees. It's an important distinction.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
Unread 10-01-2016, 21:10
ASD20's Avatar
ASD20 ASD20 is offline
AKA: Andrew
FRC #4761 (The Robockets)
ASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud ofASD20 has much to be proud of
You would also probably need bumpers running the height of your robot, so it would still meet the bumper rules when tipped over.
Unread 10-01-2016, 21:27
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I think the "transportation configuration" rules of last season could hold precedent. Teams like 1114 and 1241 had transportation configurations that were not the same orientation on the field, yet were not penalized for size violations, because they could still fit into the box. However, sizing rules were very different last year. In 2013 and 2014, where the same frame perimeter rule was imposed, I don't recall there ever being an instance of the issue you describe, although there probably wasn't an instance where that issue could have occurred.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 10-01-2016, 21:33
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
I believe the rule that may stop this is the "can't extend 15 inches past frame perimeter" rule.
You cannot change perimeter mid match so if you went from a skinny drive train to a long one you would exceed the 15 inch reach.
Thats how I would see it anyways. I may be wrong.
Unread 10-01-2016, 21:37
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Those rules do not apply this year. Instead, parse these rules:
G7 When placed on the FIELD for a MATCH, each ROBOT must be:
D. confined to its STARTING CONFIGURATION,
the physical configuration and orientation of the ROBOT when the MATCH is started.This is the state of the ROBOT immediately before being Enabled by the FieldManagement System, before the ROBOT takes any actions, deploys any mechanisms,or moves away from the starting location. This configuration is static, and does not change during a single MATCH (although it may change from MATCH to MATCH). In the STARTING CONFIGURATION, no part of the ROBOT may extend outside the vertical projection of the FRAME PERIMETER, with the exception of minor protrusions such as bolt heads, fastener ends, rivets, etc.
R3 The ROBOT must satisfy the following size constraints:
A. total length of the FRAME PERIMETER sides must not exceed 120 in. (see Figure 4-1 for examples),
B. must not extend greater than 15 in. beyond the FRAME PERIMETER (see Figure 4-2 for examples) (see G18), and
C. ROBOT STARTING CONFIGURATION height must not exceed 54 in. (note that ROBOT height may exceed this limit in-MATCH as allowed by G17).
R22 BUMPERS must be located entirely within the BUMPER ZONE, which is the volume contained between two virtual horizontal planes, 4 in. above the floor and 12 in. above the floor, in reference to the ROBOT standing normally on a flat floor. BUMPERS do not have to be parallel to the floor.
In my opinion the combination of these rules prevents any "flop bots".
2016: Lake Superior WFFA
Unread 10-01-2016, 22:31
tstew's Avatar
tstew tstew is offline
Alumni
AKA: Timothy Steward
FRC #3928 (Team Neutrino)
tstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud oftstew has much to be proud of
Last year's rules do not apply:
Originally Posted by 2016 FRC Game Manual Section 1.4;
The intent of this manual is that the text means exactly, and only, what it says. Please avoid interpreting the text based on assumptions about intent, implementation of past rules, or how a situation might be in “real life.”
Unread 10-01-2016, 22:39
jkelleyrtp's Avatar
jkelleyrtp jkelleyrtp is offline
Let's just build a robot
AKA: Jon Kelley
FRC #5511 (Cortechs Robotics)
jkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of lightjkelleyrtp is a glorious beacon of light
I know you aren't supposed to disseminate the rules from pictures but...
Cortechs Robotics 2014-Present
Mechanical, CAD
Unread 11-01-2016, 00:15
Chak Chak is offline
AKA: Thomas
FRC #4159 (Cardinalbotics)
Team Role: CAD
Chak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant futureChak has a brilliant future
Originally Posted by G1
ROBOTS whose operation or design is dangerous or unsafe are not permitted.
I find it hard to believe that a referee will allow a robot to have sideways bumpers in a match. I believe bumpers were intended to protect the world from the robot and the robot from the world. Having the bumpers sideways like that would be unsafe imo. You may not even pass inspection if you intend to do this as part of the robot design.
But if you have a way to move your bumpers down... that looks so complicated, it's probably not worth it though imo.
