Go to Post A shaft that yielded is just as useless as a shaft that broke. - Chris is me [more]
Unread 10-01-2016, 15:55
GavinL GavinL is offline
intensely stares at program
FRC #5726 (RhumBotz)
Rookie Year: 2016
GavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to beholdGavinL is a splendid one to behold
Team 5726 - Multiple errors in Eclipse path
Hello, my name is Gavin Levis from team 5726. We are a rookie team and I am the first programmer to try out C++ for our robot (I'm also a Freshman).
After installing Java JDK, FRC C++ Toolchains, and Eclipse, I have rebuilt the project to find that I have 4 errors in Getting Started. The four errors are listed below.
"Program "C:\Program Files (x86)\Microsoft Visual Studio 12.0\VC\bin\amd64\cl" not found in PATH" Resource: Getting Started
"Program "g++" not found in PATH" Resource not listed
"Program "gcc" not found in PATH" Resource not listed
"Program "gcc" not found in PATH" Resource: Getting Started
If you know what these errors are please tell me how I can fix it.
Unread 10-01-2016, 22:10
cbyrne's Avatar
cbyrne cbyrne is offline
FRC #3941 (Absolute Zero Electricity)
cbyrne is a jewel in the roughcbyrne is a jewel in the roughcbyrne is a jewel in the rough
Re: Team 5726 - Multiple errors in Eclipse path
Same errors here.
The bottom three are because while the FRC toolchain for C++ installs correctly, the name of the programs are not what eclispse is looking for.
(Working on it right now.)
Not sure what causes the first yet.
One of our students also provided the following:
https://github.com/Techbrick/Referen...ATH%22%20Error
(Side note, I am not convinced installing Mingw is the right fix for this.)
Unread 10-01-2016, 22:12
nick818 nick818 is offline
AKA: Nicholas Currault
FRC #2840 (Blue Tide)
nick818 is an unknown quantity at this point
I had the last three errors last year after I accidentally forgot to install the C++ toolchains. So try uninstalling/reinstalling those.
As for the last one, are you using a Mac? I just got that error this year because we added a Mac computer to use for development (and still haven't figured it out actually).
Unread 10-01-2016, 22:14
I'm guessing you have the wrong toolchains or the wrong plugins then as they matched in Beta.
Unread 10-01-2016, 22:24
cbyrne's Avatar
If they worked in beta, then perhaps something changed on final.
I have been installing everything according to the "screenstepslive" site. Fresh install of Eclipse Mars, C++ online install of WPILib Eclipse plugin, FRC 2016 toolchain 4.9.3 (and uninstalled, installed again), no go.
Which version of the toolchain is in the Beta if I may ask?
Thanks
(If it makes a difference, this is a windows 10, 64 bit, 64 bit eclipse, 64 bit JDK 8u66)
Unread 10-01-2016, 22:56
cbyrne's Avatar
Just found this link:
http://forums.usfirst.org/showthread...-when-building
Code does seem to build and deploy as indicated, even with the four errors.
Unread 10-01-2016, 23:20
Rookie Year: 2016
So I can just leave them there?
Unread 11-01-2016, 07:40
cbyrne's Avatar
I grew up being taught errors are not good, so I am not comfortable leaving them there. But yes, in theory they can stay.
If you want to remove them, try this:
Install MinGW (http://www.mingw.org/) - FRC doesn't use this, but other open source projects do, so it won't hurt.
At minimum, you want to install the "base" and "gcc-g++" packages.
After install, open Eclipse, and follow the instructions for appending the path in the link I provided above.
(Note, I was still getting the Visual Studio path error, but in Project Properties -> C/C++ General -> Preprocessor [...] -> Providers tab, checking "CDT Cross GCC Built In Compiler Settings", hitting apply, unchecking, hitting apply, and checking it again, hitting apply seemed to remove that. Also throw in a Project -> C/C++ Index -> Rebuild for good measure.)
Where does that leave you?
Unread 11-01-2016, 22:55
axiomofdarkness's Avatar
axiomofdarkness axiomofdarkness is offline
FRC #1403 (Cougar Robotics)
axiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura aboutaxiomofdarkness has a spectacular aura about
I am also having all four of these errors. I was able to solve the bottom three by installing MinGW and adding C:\MinGW\bin to PATH. I have not been able to solve the first error yet, however.
Unread 12-01-2016, 14:22
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Official toolchain builder here, and yes, the lower 3 errors are harmless for FRC*. The first error is for simulation, and if you aren't using simulation, is safe to ignore. I could have sworn that error was fixed in November though....
*Those errors are because we only install "arm-frc-..." prefixed tools, and using the plugins eclipse only uses them. However, the generic eclipse C/C++ tools that aren't used for FRC expect non-prefixed. Those 3 errors will only matter if you do local C/C++ dev for your system, not FRC dev.
See http://www.chiefdelphi.com/forums/sh...d.php?t=132042 for more details:
Having said that, you can make them go away by prefixing the value listed in the error with "arm-frc-linux-gnueabi-". I'm afraid I don't remember where it is off the top of my head but can provide the exact value if you copy-paste the entire error.
Watchdog.Kill();
Unread 12-01-2016, 15:11
Rookie Year: 2016
Okay, thankyou. I am going to go ahead and say this is solved.
Unread 13-01-2016, 11:52
byteit101's Avatar
If you don't care about building native C++ code and want the path error to go away, here is the full settings path:
Window > Preferences > C/C++ > Build > Settings > Discovery
then select [CDT GCC Built-in Compiler Settings] and in the text box at the bottom, prepend "arm-frc-linux-gnueabi-" to the existing text. Should end up as something like
arm-frc-linux-gnueabi-${COMMAND} ${FLAGS} -E -P -v -dD "${INPUTS}"
If you use this eclipse install for more that just FRC compiling, don't do this, instead install mingw.
Watchdog.Kill();
Unread 13-01-2016, 12:21
rsaccone rsaccone is offline
FRC #3950
rsaccone is an unknown quantity at this point
Hi,
I was seeing the same kinds of errors and I tried the suggestion of preprending
arm-frc-linux-gnueabi- on the built in compiler settings. If I did a clean and build then errors went away but now I am experiencing another issue. When I look at any source, say CommandBase.h from the a wizard generated project almost all the symbols can't be resolved. It seems like include paths were not setup correctly by the project wizard. Is this a symptom of a bad tool install or can I fix this without reinstalling. Please see attached picture for more info.
Thanks,
Rob
Unread 13-01-2016, 15:24
King Nerd III's Avatar
King Nerd III King Nerd III is offline
Chief Programmer/Head of Autonomous
AKA: Isaac
FRC #1410 (The Kraken)
King Nerd III is an unknown quantity at this point
We get these errors, too. Only when the project is first opened or eclipse starts up. Here are the steps we use to fix them:
1. Highlight the errors
2. Press the "Delete" key
3. Recompile code.
4. Rejoice because errors are now gone.
Theoretically, yes, you can leave them there. I don't like leaving them there, though, because sometimes I see the error indicator and forget to check for any new, real errors.
So, in summary, they're nothing to worry about.
Isaac
Chief of Programming and Head of Autonomous Control
FRC Team 1410
Unread 13-01-2016, 15:43
FRC #3950
I applied the changes that byteit101 suggested. However here's what I see now in the console when I do a Clean of my project:
15:37:56 **** Clean-only build of configuration Debug for project GoGo ****
rm -rf src/Robot.o src/Subsystems/ExampleSubsystem.o src/CommandBase.o FRCUserProgram src/Subsystems/ExampleSubsystem.d src/Robot.d src/Commands/ExampleCommand.d src/Commands/ExampleCommand.o src/CommandBase.d src/OI.o src/OI.d
Cannot run program "rm": Launching failed
Error: Program "rm" not found in PATH
PATH=[\usr\local\bin;C:/Program Files/Java/jre1.8.0_66/bin/server;C:/Program Files/Java/jre1.8.0_66/bin;C:/Program Files/Java/jre1.8.0_66/lib/amd64;C:\ProgramData\Oracle\Java\javapath;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\ThinkPad\Bluetooth Software\;C:\Program Files\ThinkPad\Bluetooth Software\syswow64;;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files\Common Files\Lenovo;C:\Program Files (x86)\Common Files\Ulead Systems\MPEG;C:\Program Files (x86)\Windows Live\Shared;C:\SWTOOLS\ReadyApps;C:\Program Files (x86)\Symantec\VIP Access Client\;C:\Program Files (x86)\Common Files\Lenovo;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\Intel\iCLS Client\;C:\Program Files\Intel\iCLS Client\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\WINDOWS\System32\WindowsPowerShell\v1.0\;C:\Program Files\Intel\WiFi\bin\;C:\Program Files\Common Files\Intel\WirelessCommon\;C:\Program Files\ThinkPad\Bluetooth Software\;C:\Program Files\ThinkPad\Bluetooth Software\syswow64;C:\Program Files\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\DAL;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\IPT;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files\Common Files\Lenovo;C:\Program Files (x86)\Common Files\Ulead Systems\MPEG;C:\Program Files (x86)\Windows Live\Shared;C:\SWTOOLS\ReadyApps;C:\Program Files (x86)\Symantec\VIP Access Client\;C:\Program Files (x86)\Common Files\Lenovo;C:\Users\RoboGym\AppData\Local\Programs\Git\cmd;C:\Program Files (x86)\Microsoft VS Code\bin;C:\Program Files\eclipse]
15:37:56 Build Finished (took 63ms)
15:37:56 Build Finished (took 0ms)
I don't like that rm couldn't be found and leaves me wondering if the clean actually did anyting. For the record this is a Windows 10 installation.
If I do a build following this I don't see any errors in the errors tab but in the console I see the following:
15:42:12 **** Incremental Build of configuration Debug for project GoGo ****
Info: Internal Builder is used for build
arm-frc-linux-gnueabi-g++ -std=c++1y "-IC:\\Users\\RoboGym/wpilib/cpp/current/include" "-IC:\\Users\\RoboGym\\workspace\\GoGo\\src" -O0 -g3 -Wall -c -fmessage-length=0 -o "src\\CommandBase.o" "..\\src\\CommandBase.cpp"
Cannot run program "arm-frc-linux-gnueabi-g++": Launching failed
Error: Program "arm-frc-linux-gnueabi-g++" not found in PATH
15:42:12 Build Finished (took 57ms)
Note that arm-frc-linux-gnueabi-g++ is being reported as not found.
And on top of this if I start to browse my source files I get the same errors that I posted a jpg of earlier.
This last part seems like include paths are not setup correctly as I can't jump to the definitions of any of the std runtime classes nor even class definitions that are in my own project.
Any ideas are appreciated.
Regards,
Rob
