Go to Post Injuries can come out of no where. I know this is only a robotics competition but the injury doesnt care where or what you are doing. - nightrenegade00 [more]
Unread 11-01-2016, 00:08
Lil' Lavery Lil' Lavery is online now
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: New Track Option
Originally Posted by Tom Line View Post
If you have the entire tread in contact with the carpet at once..... you probably aren't turning very well. That's a drivetrain design problem, not a tread one. I'd expect you want a drop center on this the same as a 6 wheel drivetrain - if not potentially more.
To build upon this point, it's pretty easy to vary your drops/tread profile by adjusting your pulley size. Since the torque is transmitted via the tread, you (likely) don't particularly care about the axle rotation speed. This allows you to use different size pulleys (sprockets, in this case). If all your axles are mounted at the same distance from the bottom of your frame, a larger pulley in the middle would result in a "drop center" in your tread.
