Go to Post I'll guess those tie-dyed, numbered balls are used for alliance-partner lotto. :D - Richard Wallace [more]
Unread 01-10-2016, 01:23 PM
C.Lesco's Avatar
C.Lesco C.Lesco is offline
Engineering Captain, Driver
FRC #5870 (League of Logic)
C.Lesco will become famous soon enough
Having Bumpers mounted at different Heights?
So I read the rule book and I have an idea to help cross the stone wall and moat by having the first thing for the robot to hit when reversing being treads or wheels to help climb over, like a rock climbing car To do this however Bumpers would get in the way. Could I lift the bumpers higher in the rear than in the front? Say life 5" from the ground in the rear and 3 inches in the front?) Is this against the rules? I've read and I didn't see anything specifically but what do you guys think?
Unread 01-10-2016, 01:25 PM
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Having Bumpers mounted at different Heights?
The BUMPERS must be in the BUMPER ZONE and must be protecting the FRAME PERIMETER corners. They do not have to be at the same height all around the ROBOT. The rules say they do not have to be level.
(since 2004)
Unread 01-10-2016, 02:06 PM
C.Lesco's Avatar
Wow yeah, I overlooked that bit, Thanks a lot Gary!
Unread 01-10-2016, 03:19 PM
dradel's Avatar
dradel dradel is offline
FRC #4557 (Full Metal Falcons)
dradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to beholddradel is a splendid one to behold
Not trying to hijack thread, but also have a bumper question. This is going to be our first year not using kop frame, and the plan is to have a U shaped frame. My question is do the bumpers have to come inside the U at all, or can they stop at the inboard most edge of the tips of what would be the U
Unread 01-10-2016, 03:34 PM
Jaxom Jaxom is offline
AKA: Michael Hartwig
FRC #1986 (Team Titanium)
Jaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant futureJaxom has a brilliant future
Short answer - your question is answered in R19 & Figure 4-3. One of the robots in 4-3 is U-shaped.
Long answer - bumpers have to protect outside corners on the frame perimeter. The frame perimeter continues across the mouth of the "U", that corner you're asking about having to protect or not isn't an outside corner.
Mentor http://www.teamtitanium.org/
Unread 01-10-2016, 03:37 PM
MikLast's Avatar
MikLast MikLast is offline
CAO/Drive Coach
AKA: Mikal Dieatrick
FRC #4513 (Circuit Breakers)
MikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to allMikLast is a name known to all
the bottom left picture in Section 4.7 (R19) should answer your question
Check out the FRC Discord!
2014: programmer, scout
2015: programmer, admin, drive team
Innovation in control award, WVHS district event
Innovation in control award, CWU district event
finalist, PNW district championship
2016: CAO, Drive team.
Excellence In Engineering awad, WVHS District event
Unread 01-10-2016, 04:22 PM
cca5448's Avatar
cca5448 cca5448 is offline
FRC #5448
cca5448 will become famous soon enough
As an addendum question, the manual says curves are considered to have infinite corners. Does this mean they need bumper on them or that they do not?
For the sake of example, if the frame perimeter of my robot is circle, do I need bumpers at all?
Unread 01-10-2016, 04:34 PM
GaryVoshol's Avatar
Cogito ergo arbitro
Since every corner must be protected by a BUMPER, and a circle is considered to be an infinite number of corners, the entire circle must be protected.
(since 2004)
Unread 01-10-2016, 08:23 PM
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
On a related note, I know R25 states "BUMPERS must not be articulated (relative to the FRAME PERIMETER)."
Does this mean its okay if the bumpers change height due to lowering or raising my wheels/frame to clear obstacles? I'm assuming the bumpers are still rigidly attached to to the frame and within the bumper zone as the frame height changes.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 01-11-2016, 12:28 AM
Bkeeneykid's Avatar
Bkeeneykid Bkeeneykid is offline
#wheatcoastneatcoast
AKA: Devin Keeney
FRC #1982 (Cougar Robotics); Season Long Fantasy FIRST (F3)
Team Role: Student
Rookie Year: 2015
Bkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud ofBkeeneykid has much to be proud of
Assuming they are not moving in relation the robot frame. As far as I understand, as long as the raising of your wheels does not create any new corners and modify your robot frame at all, you should be fine.
Unread 01-11-2016, 03:02 PM
mitchklong mitchklong is offline
None #4859
mitchklong is an unknown quantity at this point
Why just have them high in front ?
If your robot had longitudinal symetery (same in back and front) you could go through a defense, back up, then go through again to disable.
