Go to Post I believe that FIRST in itself is a reward. - link871 [more]
Unread 10-01-2016, 23:31
MAXOFLIFE's Avatar
MAXOFLIFE MAXOFLIFE is offline
Bolton Bear Bots Member
AKA: Maxwell Huffman
FRC #3666 (Bolton Bear Bots)
MAXOFLIFE is an unknown quantity at this point
How to wire Digital Inputs and Outputs and Analog Inputs? (SOLVED)
Hello! Thank you for taking the time to read my post and hopefully help me!
I almost completely understand how to take the values from a digital input/analog input and utilize them within our team's code, but I have no idea on where to even begin on the roboRIO itself.
For example, if I wanted this simple switch mounted on the robot to control whether the robot ran our autonomous code or did not run our autonomous code, how would I wire it to the roboRIO DIO so that I could call for it's T/F value in LabView?
The same question applies to this potentiometer, except for analog values rather than T/F.
This is a very rudimentary question that you can probably answer in minutes, but I just wanted to ask the you guys first so that I don't accidentally hurt the board. I couldn't find my answer after using google for an hour because I don't know the proper terms. Thank you for your help!
Bonus Question: What would a potentiometer that has specific values be named? Specifically one that has at least 4 distinct analog value outputs.
Unread 11-01-2016, 00:32
lethc's Avatar
lethc lethc is offline
#gkccurse
AKA: Becker Lethcoe
FRC #1806 (S.W.A.T.)
lethc will become famous soon enough
Re: How to wire Digital Inputs and Outputs and Analog Inputs?
The switch that you posted is a SPDT switch (single pull double throw). It outputs high to whichever side the switch is moved to. I'd use it as a SPST (single pull single throw) switch, because you're just looking to alternate between on and off. This means wiring one side (the 'on' side) to a signal pin of a DIO port. The middle of the switch should be wired to ground.
A potentiometer is a variable resistor. Here is a resource on how to wire a potentiometer. Wire the output wire to the signal pin on the RoboRIO.
2016: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Semifinalists, IRI Quarterfinalists
2015: Greater Kansas City Regional Finalists, Oklahoma Regional Winners, Tesla Quarterfinalists, IRI Winners
2014: Central Illinois Regional Quarterfinalists, Greater Kansas City Regional Finalists, Newton Semifinalists
2013: Greater Kansas City Regional Winners, Oklahoma Regional Winners, Galileo Quarterfinalists
Unread 11-01-2016, 06:05
rich2202 rich2202 is offline
FRC #2202 (BEAST Robotics)
Wire the outsides to Ground and +, and the middle to Signal.
For the Switch, the Signal wire will either be connected to Ground (0) or + (1).
For the Pot, the Signal wire will read the distance the pot is rotated.
You will want to adopt a convention on which side is Ground vs +.
I believe the Ports on the Robo Rio are: Ground, +, Signal. With + always in the middle, you don't damage your equipment if you accidentally plug in the connector backwards.
BTW: An easier way to control Autonomous is the Smart Dashboard. Put a field on the screen that the Driver can change. Read the value at the beginning of Autonomous.
Unread 11-01-2016, 06:55
MAXOFLIFE's Avatar
Thank you both for your help!
Unread 14-01-2016, 08:23
CryptoStorm's Avatar
CryptoStorm CryptoStorm is offline
EIC Tech
AKA: Joshua Stilwell
FRC #5056 (MegaHurtz)
CryptoStorm is an unknown quantity at this point
The signal wire should go to the pot wiper (center tap) the + and - to either side. If you put the + to the center tap you're creating a direct short when the wiper is all the way toward the -
